Things I have learned after messing with 3 different Westinghouse DPFs (1 -14" & 2 - 10").
1. Just tap the buttons. Exit first and then Menu or one of the other functions. Holding them down too long seems to nullify the functions. Only the Power button needs to be held down for a second or two to turn the device on or off.
2. Use a USB to mini-USB
cable to access the internal memory. Expect flakiness when you plug in the cable. Sometimes it will warn the USB 2 device is plugged into USB1 port. Ignore this and just look for a string of removable drive letters to show up in My
Computer window. The one named FLASH Drive is the internal memory.
3. I reformat the internal memory (FAT32 seems to work fine) and this gets rid of the troublesome canned pictures that may be causing your lock ups.
4. I have had good succcess the xD memory cards from 16MB to 1GB.
5. I have not seen any prblems with edited photos or long file names - just be sure they are named with .jpg extension and not .jpeg. - go figure?
Hope this helps...
I tried connecting it to the computer, but the internal memory is not getting mounted, I get error message saying " block 0 cannot be read".
I get the same error message, when I try to copy photo, from SD card to internal memory.
I connect the frame to the mac with the mini usb, nothing! nothing shows up on my computer.
my lcd picture frame wont accept any pictures will a firm ware download help with this issue
