Please take this steps on how to determine the problem: 1. Open the back cover. 2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter.. 3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board.. 4. If the power supply output is normal..The problem could be on the main board... 5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board.. 6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV.. Hope this solution will be helpful..
Most problems can be solved by replacing the power suppy. Try this first before you pay an outrageous price to fix it, I've had to repair 12 tv's that had problems from fading to flickering pictures. This most always indicates a power supply problem
I'm not receving any power to my PDP 502 MX and I read that this is due to a power supply failure with our particular models. You might want to contact Pioneer.
Yep. The power supply in Sanyo Plasmas are generally prone to failures. It could be a failure in the panel not priming, but I doubt it. Turn the lights off in the room, then try to turn it on. If you see the screen faintly flash, the panel is priming, but it is not coming on. If the screen is lit, but is still "black," then it is a control or digital board. If it is totally black with no light at all, then it doesn't entirely rule out the first two, but makes a power supply failure more likely.
They usually have a lot of heat damage to them. If you have tried unplugging it for 15 minutes, then plugging it back in and it still doesn't work, the it is most likely a secondary in the power supply.
