HP Compaq ProLiant DL580 G4 (430811001) Server Logo
Posted on Aug 11, 2011
How solve the problem of hp ml350 g6 fan 1611-fan failure shutdown after 5 second
4 Related Answers
Bob F
  • 48 Answers
  • Posted on Mar 20, 2009
SOURCE: HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Thomas F. Schneider
  • 2715 Answers
  • Posted on Jan 18, 2009
SOURCE: Fan flow error 1611 I/O
Either the Case fan or the CPU fan has failed.  Replace it .
Your HP support site for you product below: G2, 3, 4, 5?
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=+Compaq+ProLiant+ML370&submit.x=4&sub
Anonymous
  • 7 Answers
  • Posted on Feb 28, 2011
SOURCE: my hp proliant ml350 g6
Update firmware using HP FW dvd/cd
is issue persist, boot from smartstart cd.
Smart Start CD.
X32 version
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=3709945&prodSeriesId=3884098&prodNameId=3884099&swEnvOID=1005&swLang=8&mode=2&taskId=135&swItem=MTX-00b1501bdf9a4ddda9353d075e
x64 version
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=3709945&prodSeriesId=3884098&prodNameId=3884099&swEnvOID=4024&swLang=8&mode=2&taskId=135&swItem=MTX-3f97b02184724797ac2827ebdc
you can check the array and controller using ACU (array config util)
Anonymous
  • 1961 Answers
  • Posted on May 19, 2011
SOURCE: I just plugged in a
make sure you select the jumper on the hard disk into a slave setting and the hard disk is formatted into windows format.check the jumper settings first and post back for further suggestion.
I have an HP ProLiant dual quad core ml350 how do I find out what generation it is
The HP ProLiant ML350 G6 6th generation
you can visit www.hp.com
I have a hp proliant ml350 g6 but i can not hear any sound there is no where, where i can connect external speakers to what should i do
Most servers don't come with a sound card. There is no use for them in a work environment. You would have use an add-on card.
Fan connector broken hp ml350
Cannot disble CPU FAN CHECK / Systemboard to be repaired
LOUD FAN NOISE IN ml350g6 using non heatsink ddr3 ram
Run with case open. Check for bad fan / warning light.
1helpful
I have a HP Proliant ML350 G6 running MS Small Bus. Server 2008. It will freeze up 3-5 times a week which holds up work loads. What might be the cause of it freezing up so often? Thanks,
HEAT, is a big factor. That is a mighty Xeon Server Quad Core CPU and when it gets to work it gives off heat.
You need to make sure that the chassis is well ventilated, install some fans to keep it cool. Clean the heatsink and surrounds of dust. Use a vacuum cleaner.
Also scan the system for Malware and Virues, these pieces of code simply get the computer to do a whole lot of nothing usefull to you. Find them and delete them. Usually a good cleaning will get it operating efficiently and effectively, giving you a responsive and productive computer system.
Take care!
damnor01
1helpful
Compaq dl380 g1 - 1611 Power Supply 1 Fan Failure Detected
it only ur fan problem which one of the four fan or two ,might be stuck or jammed which starts after of couple of restarts, so i sugest u to check the fans when in operation
good day
4helpful
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
