SOURCE: Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
SOURCE: shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
SOURCE: MANUAL FOR SIMPSON EZILOAD 5.5KG WASHING MACHINE
I've seen one for $10 so if it's acceptable for you just let me know
