The problem can be temperature not set
properly or any of fridge or freezer door not closed properly and cool air is
getting leaked out. This are basic possibilities which first needs to be checked.
But if this possibilities are checked ok and still the problem is same, then
its weak compressor issue. Click the link below for more details:---
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
--------- This will help. Thanks.Helpmech.
SOURCE: Compressor not running, Fridge/Freezer not
Unplug refrigerator pull away from wall. Remove cover over compressor and feel top of compressor to see if overheating or trying to start. If too hot to hold hand on top leave unplugged until we locate the problem. This could be capacitor, start relay, overload, motherboard. This can Be fixed but we need to eliminate cause before replacing any parts. Sea Breeze
SOURCE: the fridge is not cooling and the freezer is not
the fridge is not cooling and the freezer is not freezing. The light is still coming on when we open the doors. It sounds like the compressor is still running. What do we do?
SOURCE: Our fridge freezer (Admiral GS20C63EV) stops
Good day,
Step one. Remove the light guard in the fresh food section and where the main thermostat is located is a slot where you can insert a screwdriver. This is where the timer is. With the machine running, turn the shaft clockwise until the machine shuts off. Wait 35 minutes. If the machine comes back on, the timer is o.k. if not replace it.
If the timer is o.k move over to the freezer side. With the machine having been on for at least 6 hours remove the rear panel.
Inspect the cooling coil closely. It should have a frost coating from bottom to top. If the top coils are clean, you have developed a freon leak and have a serious problem.
If the coil is active top to bottom, then you will need to replace the dual glass defrost heaters and the defrost thermostat. One or the other may still be good at the time but it isn't worth the hassle to go into the system twice.
Installing them is tedious but doable. Take your time and keep track of how it comes apart. It's a monkey see monkey do job.
Careful on pulling the new wires.
P.S.The top coils wil not be as heavily frosted as the bottom ones but must have an active coating of frost on them.
SOURCE: Hi, My fridge ( 420 ltrs)
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: My Samsung Cool' n Cool
Hello, it needs to be reset, There two reset buttons one for the frig/frez and one for the filter--drinking water/ice maker. GB...stewbison
