Kenwood KM800 Major Classic Stand Mixer Logo
Posted on Aug 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I need to replace the plastic wheel that drives the blender. Article nr #6953483 on my Kenwoord KM800. I know where to get the spare part but I'm unable to release the plastic wheel from it shaft cause I cannot lift it from it's socket. Any idea how to access this ?
  • 2 more comments
  • dirk567 Aug 07, 2011
    I know how the get the sparepart. Need advise on replacing it.
    I had the cover removed already. Under that I have the belt that drives the wheel . The wheel is in a cage and I can unscrew 3 bolts and then I can move the engine but not enough to free the wheel. The cage is preventing me from accessing the locking mechanism from the wheel. I should be able to lift the shaft higher from the cage or rotate the engine so I can lift the whole engine part higher. Not sure how the accomplish this.
  • dirk567 Aug 10, 2011
    Found it...you need to loosen the bar the lift the engineblock. Once that's loose you can extract the engine from the block and you have full access to the small metal bar that locks the wheel on the shaft. Got it off and replacement part is ordered. Costs only 3€ but sending it to me costs 7€ :(.
Electro Med Services
Level 3:
  • Kenwood Master 6,694 Answers
  • Posted on Aug 07, 2011
Kenwood Master
Level 3:
Answers
6694
Questions
Helped
1872632
Points
21433
You can release the plastic wheel by rotaing it to the clockwise direction by holding the shaft with a plair. Remember you have to hold the shaft very tightly with out rotating. Also you have to rotate the wheel very hard.
ok
Anonymous
Level 3:
  • Master 821 Answers
Anonymous
Master
Level 3:
Answers
821
Questions
Helped
172423
Points
2499
Hello,Hi, There is a lever just under where the mincer locates. This lever must be pulled sideways and then the cover can be removed. The lever is also used when fitting the Mincer in place.The lever may be stuck by food so you should be firm with it. take care.
Anonymous
Level 3:
Genius:
  • Master 1,456 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1456
Questions
0
Helped
475843
Points
4013
Hello
try this website to get the part you are requesting www.spares2go.co.uk
I have a KM800 and the speed setting doesn't work properly, on slow it will go fast then slow and doesn't speed up and slow down as it should. is this repairable, as it's bloody annoying when you disa
Hi Emma,
Not going to be much help here to be honest. We have the KM020 and this is the only problem we have had with heavy machine use in 4 years - and a minor issue at that.
This place is good for spare parts http://www.buyspares.co.uk/
If you're in the UK, you can call this number 02392 392 333 and give them your post code, they'll let you know who the local service agent is.
All the best,
I need a replacement bowl. Where can I purchase one
You can buy genuine spare parts for most models of kenwood chef at http://www.4kenwood.co.uk/cgi-bin/home.pl?gclid=CNWP5ffou60CFUUPfAodnj9lAg
I have a Kenwood Major mixer that gives off smoke an electrical burning smell from the motor when running. Is it worth repairing?
hi its not necessarily the motor but could be some capacitors on the speed control unit ( the control knob is attached to it) spares are reasonable to buy .you can find a dealer from kenwood.co.uk website..
How does the Bleder work?
ON THE TOP RIGHT SIDE TAKE THE COVER OFF
3helpful
Can't get the drive coupling off my Bosch Universal to replace it
I have had my Bosch Universal Mixer with the Blender and Food Processor Attachments since 2005, and I've loved it since the day I got it... that is, until the blender broke while my son was crushing ice to make slushies...
I figured out the "drive coupler" was stripped and needed replacing, but I couldn't figure out how to take apart the "blade assembly" which includes the "drive coupler" part...
My retailer, Pleasant Hill Grain, sent me the following email:
"I am not aware of any printed instructions for removing the old coupling and
replacing with the new. We recommend holding on to the blades with 1 hand and a
towel and using a needle nose pliers to unscrew the old coupling. You would put
the new coupling on in the same manner.
If these instructions do not work, I would suggest contacting the Service
Dept at Kitchen Resources in Utah. Their phone is 800-692-6724."
I still couldn't figure out how to take apart the blade assembly, so I did end up calling the distributor, Kitchen Resources...
Dave, the tech @ Kitchen Resources, answered my call on the first ring...
Once I explained my problem, he started giving me the same instructions Pleasant Hill Grain gave
me... I explained to him that holding the blades tightly wasn't working for me.
As it turned out, holding the blades did not secure the drive shaft because
the drive shaft was broken off INSIDE the blade assembly - which is why I could
not unscrew the old drive coupling part.
Dave's next question revealed the true issue at hand... my Blender Attachment has the blade assembly made of plastic - they switched to plastic
in 2005 because the metal assembly turned black in dishwashers.
Bosch just recently went back to using metal for this part - apparently the
plastic blade assembly didn't hold up.
Kitchen Resources - the U.S. Bosch Distributor - is sending me a new blade
assembly - no charge, he said it's covered under warranty. Woo Hoo!
Best of all, I hadn't yet purchased the replacement drive coupling part, because
I wanted to know how to go about replacing the part before ordering a new part.
With shipping this part would have been a $50+ repair - you have to love
customer service of that caliber!
[Aside: You really don't need to ever put this part in the dishwasher - wash
the inside with by putting hot water and perhaps a little dish detergent inside
the blender and turning it on - rinse the outside under the sink... no
dishwasher needed! ]
Kenwood mixmaster spare parts
Hello you need a complete mincer, or a mincer part ?
try in 4kenwood.co.uk ( be careful )
or in Ebay.co.uk
Billingtonelec.co.uk
regards
Kenwood Chef Restore
2answers
Kenwood Major Model number A707/A
Hello in ebay, you can get a gearbox for A701/A models ..
if you Kenwood is 1962 - 1975 is A701/A
looking the gearbox for this model. or in Billingtonelec.co.uk
Regards
Dough hook plastic guard is broken
The spare part number for this shield is KW434794
Top Kenwood Food Mixers Experts
vince
Ngoro
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
