Tip & How-To about Belkin Basic Wireless Router
To get rid of multiple issues with belkin routers
To resolve the issue with Belkin routers:The routers that are released recently by Belkin Inc., are Basic / Connect N150, Surf / Surf N300, Share / Share N300, Share Max / Share N Max300, Play / Play N600, Play Max / Play N600 HD
  • These routers comes with a software CD.
  • Belkin router monitor is the software that gets installed in the computer when you run the setup CD in your computer.
  • This software is really an unwanted one that takes around 30 minutes to get installed in your computer.
  • In addition to that, this software displays unwanted popup messages.
  • 90% users are not aware that they can use the routers without installing any software in their computers.
Inorder to make your router properly, these steps has to be followed...
  • The belkin router monitor software has to be uninstalled from your computer.
  • Firmware of the router has to be updated to the latest version available from the belkin support site.
  • Self healing feature of the router has to be disabled.
  • Wifi protected setup (WPS) has to be disabled.
To uninstall the belkin software:
  • For Xp computers, Goto control panel > Add or remove programs > select belkin setup and router monitor and remove it.
  • For vista & win7, Goto control panel > Uninstall a program > select belkin setup and router monitor and remove it.
To update the firmware for your router:Goto http://www.belkin.com/support/
  • Select your router and download the firmware for your router. The file with a .bin extension will be downloaded to your computer.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Open internet explorer / Firefox or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router http://192.168.2.1
  • Belkin router setup utility will be displayed.
  • Login to the page. (password: leave it blank and click submit)
You will have the status screen.
In the status screen, you will have the very first box in the centre of the screen says "version info", under that you will have firmware version.
Just note down the firmware version there. If the firmware version in router is lesser than the one downloaded from support site, then the firmware has to be updated.
On the far left side below the Utilities you will have "firmware update", you need to click that.
Now on the right hand side you will have "browse".
Click on browse and locate the downloaded .bin file from your computer and click update.
Click ok for all the warnings.
You may see a count down now.
Once its done you will be brought back to the status screen.
Login to the router again with a blank password and click on restore factory defaults below the utilities and click ok for all the warnings.
Now the firmware of your router must have updated with the latest version.
To disable Selfheal:
On the far left side below the Utilities you will have "self heal", you need to click that.disable the self heal and apply changes.
To disable WPS:On the far left side below the Wireless you will have "wifi protected setup", you need to click that.wifi protected setup will be enabled by default, disable it and apply changes.
Click here to learn more about wps...
Belkin Basic Wireless Router Logo
how can i get belkin n300 to recognize motorola SB6141?
Well kindly reset the belkin N300, try connect, most probably will get connected....By the by, which mean are you going to connect both? is through lan cable or wifi?
belkin n150 cisco vpn
hi - I just had a tough day trying to connect N150 to my company's VPN, and after a long struggle found out that Belkin N150 does not support the VPN connections. simply upgrade it to N300 and you would be fine.
can't connect to a second wireless SONOS via Belkin Surf 300
Go to the router web UI and see if is there then grant access to it.
Belkin N300 router, renamed network, having many issues with my 4 yr old Dell 1520 connecting to the net, network often say 'unidentified network'. takes lots of fiddling to connect. however, wireless devices seem to be able to connect with few problems. should I unistall then reinstall router?
The best solution is to delete your network and create a new one
Also reset your Belkin Router to factory default settings.
This would take care of your issue.
If you need suitable assistance you can also get online technical support. I would suggest you to contact TheBestPcDoctor. I get my issues fixed by them.If you need you may also contact them @
www.thebestpcdoctor.com or via 877-407-9229
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
