20 Most Recent
Belkin Surf N300 Wireless Router (722868807347) Questions & Answers
I want to set up
Some routers won't allow wireless repeating (which I think is what you are trying to do). Some powerline adapters would be the easiest way to solve this as they work through your electrical cables. Plug one in where you already have a network connection and the other where you want it. You can then connect the cable to the N300 (provided it has multiple ethernet ports) and then connect the rest of your devices to the remaining ports. You'll need to do some googling to configure the router correctly.
And orange bliking light came
If your belkin wireless router is flashing orange, it more than likely means it was hit by a power surge or got wet and popped the circuit on the mother board of the router. Took mine apart and found where the circuit had been blackened by power surge hitting it. I was able to salvage one important thing was the antenna that can be adapted to other systems if you know what your doing.
How do i make my lg aspire connect to a belkin router?
You should be able to see there is wireless networks available by the 5 bar slope on the right hand bottom side of the screen.
If so You can click on the icon and choose which router to access by the name, your should be Belkin.
Then put in the wireless password you set up.
If you have not set up the router you need to physically connect to it by plugging in a cable from the pc to the router LAN ports, you cannot set it up via the wireless network.
See the webpage here.
Setting up the Belkin router without using the Setup CD
Lights
Hi,This router only has 1 network status lightBelkin product page:
LinkQuick help guide:
Link
Cd wont work in my computer
You can setup your Belkin without an installation CD. Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1 The default PW = blank (just press Enter) You can now change the default admin password. You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
How to open NAT
With Belkin you have the option of disabling Firewall, or setting up a Virtual Server. You must provide the port based on program / game requirements.Almost forgot, it does allow for 1 IP in the DMZ. This is you best bet. Easy peesy, nice and easy. gl
Kinking in an out
1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
