Tip & How-To about Sony Ericsson Walkman W810i Cellular Phone
Phone Lock Code Lost! No problem get it here!!!
Hi! I have noticed a lot of people have this problem that they actually forget there Sony Ericsson mobiles' Phone Lock Code. If you want to recover your phone lock code please go through the following procedure. This procedure will tell you your mobile's lock code without flashing and resetting of any kind!..
I have also have a Nokia version of this tutorial here: Nokia
Follow these steps;
  • Open this link, select your phone and download the software. (PLEASE CLICK HERE)
  • Follow the onscreen instructions to install the software.
  • Once installed, turn off the mobile and remove thebattery. Now reinsert the battery and insert the cable (DCU-60 thatcomes with the box) while holding the 'c' or '@' button on your mobile.
  • Your computer will detect a new device and install it.
  • Once installed please unplug your mobile, remove the battery. Now reinsert it.
  • Download xs++ from here
  • Extract this file and run XS++.exe
  • In XS++, click Connect.
  • Hold 'C' or '@' key on your phone and then insert the USB cable.
  • u can get some information about your phone when it's connected
  • click or tick GDFS at the bottom.
  • Then click Phone Lock, it will show you the code on right hand side. Note that code.
  • click Settings at the bottom, then Disconnect.
  • unplug the USB cable, remove then reinsert the battery.
  • You are done, enter 0000 or the Noted one (In the 3rd last step)
    If I was Helpful, Kindly Do Rate!
    Regards,
    Waqar.
    Sony Ericsson Walkman W810i Cellular Phone Logo
    Forgotten phone lock code for handset k750i
    Hi Friend,
    I Kindly let me know ur IMEI of your mobile.I can be found by typing *#60#.U will be receving a serial no kinly provide me i will provide the solution
    Regards,
    Ayyasam
    4answers
    Sony Ericsson W580i
    you will need to take the phone to a mobile service center to ahve the code reset
    5answers
    forgot phone lock code for sony ericsson w850i
    the best way to change this is to called your service provider or SE. They know how to recover something like this.
    Top Sony Ericsson Cell Phones Experts
    Sean Wright
    Sean Wright
    Kolbrun...
    ZJ Limited
    ZJ Limited
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
