20 Most Recent
Dynex DX-E101 Network Adapter Questions & Answers
Dynex 1.3mp driver update for windows 7
Unfortunately, Dynex no longer provides driver updates for their 1.3MP webcam on Windows 7 as the product has reached its end of life and is no longer supported. However, you may still be able to use the webcam with the existing drivers that came with it or with the generic drivers that are built into Windows 7.
To check if your webcam is recognized by Windows 7, follow these steps:
- Plug in your Dynex 1.3MP webcam to your computer's USB port.
- Click on the "Start" menu and select "Control Panel".
- Click on "Hardware and Sound" and then select "Device Manager".
- Look for the Dynex webcam under the "Imaging devices" or "Cameras" category. If it is listed, then your webcam is recognized by Windows 7.
If your webcam is not recognized by Windows 7 or is not functioning properly, you may want to try downloading and installing a third-party driver update software like Driver Booster or Driver Easy. These programs scan your computer for outdated or missing drivers and automatically download and install the latest versions for you.
Alternatively, you can try searching for a compatible driver on third-party driver download sites, but be cautious as some of these sites may contain malicious software. It is always recommended to download drivers from the manufacturer's website or from trusted sources.
Have a dynex optical mouse model # DX- PWLMSE how does it connect
The Dynex DX-PWLMSE uses a 27 MHz frequency wireless connection between the mouse and a specific USB receiver. For the specifications, see
https://www.dynexproducts.com/pdp/DX-PWLMSE/8632063 .
To use the mouse, you need to press the Eject button behind the scroll wheel. This lets you open the battery/USB storage compartment. Put two AAA batteries into the mouse. Then remove the USB adapter (it's between the two battery slots). Close the storage compartment and put the USB adapter into an available USB 2.0 slot on the computer with a version of the Windows OS above Windows 98. (Note: the specifications I see indicate Dynex wrote drivers for Windows Vista. It may not work with Windows 7, 8 or 10.) Make sure that the computer is on and can get driver updates from on-line sources. Turn on the mouse and it should auto-pair with the receiver. If there is no response, try pressing and holding the connect button on the bottom of the mouse.
I'm not aware of any vendors that sell the USB receiver for this mouse. The manual for the DX-PWLMSE is available from Manuals Lib:
https://www.manualslib.com/products/Dynex-Dx-Pwlmse-Wireless-Optical-Usb-Laptop-Mouse-4908.html .
I hope this helps.
Dynex DX-46L150A11
That could be the graphics card, power supply in either the monitor or the computer, motherboard or the monitor. You might try a different monitor as a test to try to narrow down the problem..
Dynex Easy Transfer XP to Windows 7 not working
Remove old drive from computer and install in new computer using ide ribbon. It will connect as a secondary unit and you can then using windows explorer transfer any data on old drive to new one.
