20 Most Recent
Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph Xact JTAS - 10XL50 - 1PK 3HP 1Ph Xactasaw Left with 50 Ence Table and Legs , Tablesaws - Questions & Answers
The table saw shutdown where is the restart button
Usually the reset for table saw is on the motor itself
Crawl under the table and check it out & check your motor name plate (use a digital camera to photograph the name plate so you can see it large on your computer and have a record of that information)
Look for oil caps at the bearing ends of motor, to see if your motor can be oiled using 3-in-1 oil
If your saw is shutting down, you may not have enough electricity for the motor
Look at motor name plate for volts amps or watts.
Now figure how much electricity your saw need using the formula Volts x Amps = Watts
Next, look at the circuit breaker and size wire
15Amp breaker = 1440+watts
You can figure the breaker load using V X A = W
Next look at your wire going to table saw
14 gauge wire for 15 amp breaker
12 gauge wire for 20 amp breaker
10 gauge wire for 30 amp breaker
You might benefit by running bigger wire to the saw. And adding some oil in the oil caps.
I oiled my table saw and then ran a dedicated 30Amp wire to it, and it runs real good for a 25-year-old craftsman.
10/20/2010 11:21:31 PM •
Jet...
Answered
on Oct 20, 2010
Jet saw Manual for a JTAS-10/12
Jet's Manual site is
here. There are a number of manuals for Jet table saws there. I believe the exact manual you want is
here though.
If this helped, please vote. Thanks!
6/14/2010 4:18:45 AM •
Jet...
Answered
on Jun 14, 2010
Jet 10
Adjust the stop screw under the saw top plate.
9/11/2009 12:53:37 PM •
Jet...
Answered
on Sep 11, 2009
I own a Jet Left Tilt Cabinet Saw Mdl 708663PK.
I took the front cover off of the switch and noticed the portion of the switch the off button contacts was fully depressed and would not slide back to its proper position. I lubed (silicone) the slide portion of the off switch and cycled it manually to free it up and distribute the lubrication.
2/19/2009 4:53:30 PM •
Jet...
Answered
on Feb 19, 2009
Therma Overload Switch
If you have not supplied enough power (like using an extension cord) the motor sees a big voltage drop, starts drawing a lot of current and eventually overheats. Make certain to use a good supply.
JET Tools
2/5/2015 9:19:38 PM •
Jet Saws
Answered
on Feb 05, 2015
How do i adjust the blade tilt
There should be 2 handles: height and tilt. Tilt is typically located perpendicular to the blade on the base of the saw.
1/28/2015 8:38:11 AM •
Jet Saws
Answered
on Jan 28, 2015
How do i adjust a jet bandsaw jwbs-9 blade tension
You should check your manual. There's a blade tension handle on my bandsaw, which is adjusted every time I need to change tension or change blade. There ways how to check the correct tension, you can pluck the blade like a string on a guitar and if you hear music not like sound, tension is good. Or you can follow the suggestion blade tension on your saw. or you may also use tension gauge.
7/25/2014 6:53:18 PM •
Jet Saws
Answered
on Jul 25, 2014
