20 Most Recent
Jet 708100 Jwts 10 1 1/2HP Workshop Table Saw Questions & Answers
Jet table saw JWTS-10CW2 blade
The table needs to aligned with blase and mier slots. I used a dail caliper to measure distand
ce from the front of blade to rear of blade. Use a piece of tape to mark tooth and use that tooth to measure front and the rotate and measure back. usually there are 4 bolt that hold table. Lossen only 3 and slack off the 4th to help hold table . Use a block of wood and hammer to tap table in alignment. DO NOT GET WILD or you will have more work resetting everything. The alignment is usually of a small amount. Good Luck
Reset button does not reset,
This link will take you to the parts number search page. Otherwise, start
here and find
your product, choose "Find Out more" to get a copy of your owner's manual, in which you'll find a complete parts list, with parts numbers. Then go to the first link to choose and order parts.I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
How do you align the motor on an older (JET)
Remove the drive belt, loosen the motor base bolts on the motor and put a straight edge on the outside edge motor pully rotate the motor till the straight edge lines up with the outside edge of the saw blade pully then retighten the motor base bolts and replace the drive belt.
Saw worked fine until today. Kicks breaker
What I would check for and follow closely, is UNPLUG tool turn blade by hand to make sure it turns freely, there could be a piece of offcut wood jamming the blade. then turn it on its back or however you can to see about cleaning with compressed air, check the cord condition for breaks if all the above checks out and sounds like you have tried different power sources you have an electrical short and troubleshooting this is involved.
Table saw cuts off
Probably the overload trip is set to too low a current. Either this or it is faulty.
It is just possible that there is dust in the contacts which causes a bad contact but it is more likely to be the overload trip.
Blade type
blades are available for different applications. A few common blades include:Steel Blades are inexpensive and work well for cutting softwood. Steel blades dull quickly in hardwood. High-Speed Steel Blades are harder than steel blades and stay sharp longer. Carbide-Tipped Blades are more expensive than other blades, but they stay sharp much longer than steel or high-speed steel.
