20 Most Recent Hitachi 57F710 TV Questions & Answers
2answers
Lightning struck my house last night, the tv is
physically remove the power cable for about 10 mins then reconnect it no joke this is important
if it does not work the power supply is needing replaced
do you have cable or sky
1/6/2017 3:49:30 AM • Hitachi 57F710... • Answered on Jan 06, 2017
The place where you plug in hdmi is crushed how do i replace it
The old one will have to be wicked off and a new port will need to be soldered on to the board.
If you can Solder it's not bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
1/19/2016 5:50:42 PM • Hitachi 57F710... • Answered on Jan 19, 2016
What is the replacement bulb part number for my tv.
Good question. What kind of tv are we talking about? If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
1/19/2016 5:44:50 PM • Hitachi 57F710... • Answered on Jan 19, 2016
Sound but no picture,black screen hitachi#50GX30B Was watching Tv then I think I heard a little pop and no picture just sound
hi voltage transformer went need a professional to fix unless you can get parts and solder it in
3/27/2014 3:45:50 AM • Hitachi 57F710... • Answered on Mar 27, 2014
Red power light on but no picture
make this test and fix it. God bless you
  1. Verify TV is plugged-in and getting power.
  2. Verify your home's power breaker has not tripped.
  3. Verify the batteries in the remote control are good.
  4. Verify you have selected the right input for Cable/Satellite, antenna, DVD, VCR or Game Console.
  5. Verify the cable/satellite box is plugged in and getting power
  6. Verify you are getting cable/satellite in other parts of the house
  7. Verify the VCR is plugged-in,getting power, and turned on.
  8. Verify that all wires are connected to proper place
  9. Scroll through input screen to verify you are watching the correct inputs
Look at the FAQ on the manufacture's website or user manualUse your remote control. The first step is to inspect the batteries of the remote control and see if they are functioning. If its power button starts to blink several times once you turned it on, then the batteries need to be replaced. See to it that your remote control is used within about 20 feet from the television. Make sure also that nothing blocks the space between the remote control and the receiver.
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
7/31/2013 2:21:14 PM • Hitachi 57F710... • Answered on Jul 31, 2013
Someone cut off the power cord for my Hitachi 51f710s and not certain where the power supply is
That one I am fairly sure had a plug on cord---look where opening for cord is and inside for two metal pins in a socket---rectangular with white plastic.
4/20/2012 2:55:45 PM • Hitachi 57F710... • Answered on Apr 20, 2012
What r the little red peices wired all around the inside of the screen
Those are light sensors that will change the brightness slightly with light changes inside the room
3/26/2012 3:53:57 PM • Hitachi 57F710... • Answered on Mar 26, 2012
My Hitachi 57F710 TV turns off as soon as it turns on?
The model indicated is a DLP which uses a lamp---lamp will not usually cause set right on and then instantly off----takes it 15 seconds or so if lamp has failed.Also set has led on front that may blink.If instant it is turned on it goes off----you have a short likely in power supply or elsewhere.If you have more information or a question press the "make a comment button" on this page.
3/26/2012 3:17:30 PM • Hitachi 57F710... • Answered on Mar 26, 2012
0answers
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
1/26/2012 2:24:58 AM • Hitachi 57F710... • Answered on Jan 26, 2012
Hitachi 52fdx20b TV; power light will not turn off
if power light is on most of the set inside is on.Follow power cord inside set and on power supply board look for up to three rectangular black relays that are there-----they will be marked with relay voltage in white.Gently tap with something not metal on each until the power light goes off.What happens is one of the relays sticks in the closed position.If the power light goes off when you do this the relay is bad and if there are three the part number is printed on them----replace all three as they each have only 4 solder connections and are generally under 10 dollars each (wholesale about half that).If tapping stops it sooner or later it will do the same thing again.SD TECH
9/21/2011 4:03:39 PM • Hitachi 57F710... • Answered on Sep 21, 2011
TV is making a crackling sound on left side of tv
Sounds like the flyback transformer. You can get a replacement flyback from www.tvrepairworld.com and assistance to help you identify if the flyback is the issue
6/6/2011 3:52:05 PM • Hitachi 57F710... • Answered on Jun 06, 2011
I want to connect my
try search the vga or hdmi connector if you see a vga or hdmi connect it there and set your tv to one that has the the pc.
10/15/2010 8:28:23 AM • Hitachi 57F710... • Answered on Oct 15, 2010
Have a 57f710a tv was workin fine earlier today,
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
8/13/2010 2:47:56 AM • Hitachi 57F710... • Answered on Aug 13, 2010
Edges of picture being cut off. Is there
Have you tried changing the aspect ratio? On your remote there should be a button labled aspect. Otherwise you'll need to access the service menu and change the vertical height and horizontal width.
8/7/2010 1:29:40 AM • Hitachi 57F710... • Answered on Aug 07, 2010
The picture keeps growing larger
Hi
Thanks for using FixYa. The issue is with the failed convergence (STK) ICs which needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
7/14/2010 1:20:22 AM • Hitachi 57F710... • Answered on Jul 14, 2010
My hitachi tv's picture is distorted red and green like a 3-d pic
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
5/15/2010 4:41:09 AM • Hitachi 57F710... • Answered on May 15, 2010
Pitcher has double pitcher and one is in diffrent
you need new convergence chips, 2 chips stk392-110, they have to be soldered in, very common problem, you also want to t\check for burned resistors around the convergence chips.
9/15/2009 6:14:51 PM • Hitachi 57F710... • Answered on Sep 15, 2009
Hitachi tv shuts off . When I turn on the TV iMessage says please wait then turns off two seconds later.
That sounds like it is not booting properly. I would check for correct power supply opperation and if not that, look for a software reloading procedure in the user instruction manual.
2/11/2024 9:04:18 AM • Hitachi... • Answered on Feb 11, 2024
Hitachi 57F710 TV Logo
25 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
hitachi 52fdx20b tv power light will
  • Televison & Video
