20 Most Recent
Polaroid a550 Digital Camera Questions & Answers
Question
If it stayed shut before it will do again.
Take the batteries out. check for anything in the compartment, put them back in checking that they are the correct way round and fully inserted always spring end first then the little positive button last.
Push them carefully fully home and the door should shut.
Patience usually worked in the end.
Why my camara reads card
Take a look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
My poloroid digital camera is
With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, your card should work properly.
New batteries in, turn on and Polaroid comes on
Not all batteries are created equal, especially in digital cameras. Try lithium ion batteries (Energizer Advanced or Duracell PowerPix) or quality NiMH rechargable batteries. Regular alkalines, especially some of the cheaper ones, are not recommended regardless of what the manual says.
I cant get my pics to go onto the memory card they
The problem is you are using a SDHC SD card (>2gb). They are not compatible with the a550. You need a 2gb or smaller standard SD card for it to recognise in the camera. Th epictures will then save onto it no problem.
I have formatted and have bought a new memory card
Make sure you are saving your pictures to the card, not the internal memory Next, make sure you have alarge enough card to hold a good amount of pictures. Next, set your picture size to something lower. Pictures can take as much as 6MB eack or as little as 1/4 MB each.
Green light flashing on Polaroid iE 6035
The green light flashing on your Polaroid iE 6035 camera typically indicates that the camera is in standby mode or that it is charging. If the camera is not charging, it could be a sign of a problem with the battery or charging mechanism. If the green light continues to flash even after charging, it may be necessary to take the camera to a professional for repair or to have the battery replaced. Before seeking professional help, you can also try resetting the camera or removing and reinserting the battery to see if that resolves the issue.
