20 Most Recent
Sony Ericsson W830i Cellular Phone Questions & Answers
W830i network problem. plzzz help
Chander , i liked you because described well your problem. i think can advice better, look i think when your device fall down maybe is affected in external antena or internal antena of device which keep a network, so try to assembly and ressembly the device and look if external antena is not damaged, otherwise problem is with PA (circuit who control network) in this case you need you give some rapairer to make jump or change it, in this 2nd cenario it will cost you. i think this will help you.
Screen flickering problem in w830i
No, it is probably the fact that the phone is from so far away, it obviously was not made for use in the US so the signals emitted by cell towers here can affect that or the other thing is the phone may just be defective and it may need to be replaced but seeing as how you got in from India it doesn't look like that is going to happen. My suggestion: get a new phone, and quick before you wake up one day and your phone won't work at all. Hope I"ve helped, sorry your having so much trouble with this. Hope i've helped shed some "light" on your issue. :)
White screen
Hi
If its white screen then its time for you to replace the screen of your phone.
thank you
I lock my phone and can't unlock it
You'll have to use a Sony PC service software and its programming cable to see the phone code and unlock it, you can do it by yourself or take the phone to a technical service center, if this procedure is done correctly, it should not erase any data from phone, since it's a reading procedure.
My SE W8301 went blinking
get ur phone display changed tats it... don't get any thing else done to ur phone like firmware update or restore or any software related issues..
Hello dear sir, please give
http://www.tsar3000.com/Joomla/index.php?option=com_content&view=article&id=77:sony-ericsson-schematics&catid=53:schematics-sm&Itemid=79
http://hotfile.com/dl/62080893/40a5ae6/W380_Z555_schematic_TSAR3000.com.rar.html
download ur file der... tat has all schematics of w830 :)
On and 10second off
hi :)
about your pro have 2 possible make it.
1 : phone ribbon spiol.
2 : phone software pro.
Both pro u need send for technician.
My phone sony ericsson w830i
It can be done only if you have kept a backup of your phone somewhere. To the max you can try to connect your phone as an storage device through your usb data cable. Using data recovery software you can try recovering files on your mobile. But there are very less chances. You can take it to a service center and tell the person not to re-install the OS but to try to repair the corrupt OS. If the repair is successful your data will be safe. If not then there is no chance of getting back your contacts.
I have sony erison w830i model. even after
Format the memory card using some other mobile or using computer. If then also it is not working then the memory card is damaged.
Also pls check whether the card u r using does not exceed the limit of the phone(I think it supports only 1GB external memory. If u r using a card having more memory than that, it will not be detected)
HI.. my Sony Ericcsson W830i can't be send message
go to msg settings
set ur msg center no correctly,
collect msg center no from ur mobile operator or any other friend,,,,,,,
hope ur problem may fixed,,,,,,,,
