20 Most Recent
Miller Hobart AirForce 250A Plasma Cutter w/Builtin Air Compressor Questions & Answers
Hobart 250ci quit working
Provided Air is between 60 and 80 psi (common operating range).
Power is measured to be in range as per label or manual specs.
Replaced all consummables on the torch head.
Usually the next step is to change the Torch Head. After all else fails this is usually the problem, especially if the torch head became hot while cutting.
Need to know how to
Any authorised dealer that sell Hobart should be able to order one for you for a minimal charge.
Try Googling it.
eg: hobart dealer distributor city state
or hobart dealer miami fl
My Hobart 250 airforce doesn't start
On the main circuit board for the power supply, there is usually a thermal fuse installed, its a sealed unit and is not servicible, look for a black epoxied case,approx 3/8x3/4 long, with 2 leads coming out of it. Inside is a set of bi-metal contact points which serves as an over voltage/over current protection. These contacts deform/corode over time and it sounds like there not contacting properly. As soon as you try to load the machine, the current passing through this high resistance heats these contacts up, and shuts off power to the unit. I am not familiar with the guts of a hypertherm, but have extensive experiance repairing inverter based plasma cutting equipment, and i have encountered this before. I assume hypertherm must have some equivelent to this thermal switch inside the power supply.....Good luck..
Hobart 250 a keeps cutting off the flame
If you have a bad air supply then the moisture in the air will cause the torch to cut off and the cut quality depends also on air supply,speed,metal thickness and condition of your consumables,meaning your electrode and other related parts in the torch tip.Hope this helps
P-7 error in miller co2 welding machine
The P-7 error in your Miller XMT 304 CC/CV welding machine indicates that the input voltage is too high, causing the unit to automatically shut down. However, operation will resume when the voltage falls within the acceptable upper range limit (which is 15% above the applicable input voltage). Here are some steps you can take to troubleshoot and address this issue:
Check Input Voltage: Verify that the input voltage is within the specified range for your machine. If it exceeds the acceptable limit, consider adjusting the power source or using a different power supply.
Inspect Bleeder Resistors: The P-7 error is often related to the side output board, particularly the bleeder resistors. Ensure that these components are functioning correctly. If any of them are faulty, replace them.
Examine IGBTs: Inspect the IGBTs (Insulated Gate Bipolar Transistors) on the side board. Even if they appear fine, remove the output board and verify the protection diodes on it. Sometimes, an IGBT may have a damaged base that isn't immediately obvious.
Be Cautious: When working on the machine, be extremely careful. There are high voltages (around 325 volts) stored in the large capacitors, which can be fatal if mishandled. Always wear appropriate protective gear and follow safety precautions. The complexity of the device may require expert assistance.
