20 Most Recent Miller Trailblazer 302 Welder Generator 907217 907216 Questions & Answers
Check your machines fuses. For location of fuses look into your owner's manual.
Miller... | Answered on Jan 22, 2017
Both sets of the 120? If both of those are there (all 4 outlets), then the machine is producing 220v. So get a flashlight and look into the holes on the 220 receptacle, or check the wires on the backside of the receptacle. All that 220 is, is two 120 volts out of phase.
Miller... | Answered on Feb 23, 2015
www.millerwelds.com have the serial number handy. Click on service, then owners manuals and follow the directions.
Miller... | Answered on Feb 03, 2015
turn up the amps
Miller... | Answered on Oct 17, 2014
Replace coil. Check power to coil first with a test light. If there's power, then coil is bad or the problem is under the distributor cap. Could be air gap has moved wider or the rotor tip is dirty. Clean it and try again. It's rare the air gap will move. Could be some rust on the rotor from condensation. clean it all. Try it. still no run, replace the coil.
Miller... | Answered on Oct 15, 2014
Check the governor unit. Miller is a good make, shouldn't be a problem downloading a manual.
Miller... | Answered on Sep 05, 2014
The oil is used as a cooling system, therefore if you ran a machinery without expect to overheat, dismantle your welder and check which parts have melted, repare or replace them and make sure there is enough oil at all time
Miller... | Answered on Jun 08, 2014
Miller Trailblazer 302 Welder Generator 907217 907216 Logo
80 questions posted
Top Miller Welding Tools Experts
David Soto
David Soto
Steve Allison
Steve Allison
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Miller Welding Tools
Most Popular Question
miller trailblazer 302 wont start carb
  • Welding Tools
