20 Most Recent
Mr Steam Mr. Steam Butler Package - MSBUTLER2RD-ORB - Oil Rubbed Bronze Questions & Answers
No steam is coming out anymore
hi
it a sign of the pump ceased up or the electric motor faulty capacitor .
check if you can manually turn the pump freely and then check the capacitor
1/2/2018 11:58:03 PM •
Mr Steam...
Answered
on Jan 02, 2018
Mr Steam MS Super-1 kW: 10 doesn't generate steam
the first thing the generator should do when you hit the on button is fill. You will hear the water entering the tank. Once the water stops it indicates that the water has reached the water satisfied level, after which you should hear a loud click(your contactor engaging for the heat cycle, newer units will have all three light on the side lit). After this point is you aren't getting any steam after 5 minutes it probably means your heating element may be damaged. It would be best to remove the element at this point from the left side of the unit via 6 bolts and 2 wire leads. Any physical damage on the element such as a pinhole pop, burn mark, melting, or scar will surely prevent the element from heating
8/13/2014 12:12:29 PM •
Mr Steam...
Answered
on Aug 13, 2014
My steam iron does not produce steam
The steam jet ports (small nozzles / jets) collected mineral over time.
You will need CLR mineral remover to clean the jets.
See video below for more info.
http://www.jelmar.com/CLRbasic.htm
1/16/2014 10:33:18 PM •
Mr Steam...
Answered
on Jan 16, 2014
