20 Most Recent
Daewoo KOR-860A Microwave Oven Questions & Answers
How i can fix problem?
What you call all functions, I think it's only the front, the keys and the display. I think the main fuse or circuit breaker has tripped. Because when the magnetron does not work nothing will become warm.
microwave ovens should not be opened by normal users. The voltage used to get the magnetron fire is very high and can kill you when you touch it. To reach this voltage, there are capacitors inside, that can hold this voltage for a long time. So even with no power cable attached inside can be dangerous voltages. Please don't try to do this yourself. If you want it repaired visit a repair centre, but opening and replacing the defective parts can cost more than a complete new microwave. So first ask what it could cost you if you bring it in for repairs. And check what a new one will set you back.
I need to order your Daewoo microwave Model # 861 BLK
We don't sell microwave's. We don't sell anything. We only try to help people with answering questions. Not more not less. So if you want to buy, or already bought a Microwave, you have a complaint of, please contact the firm that sells, or sold.
My daewo microwave oven Kor 860A start button
Possible that the pad is not working or a possible failure.
Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.If only the start button is inactive but you are able to set timing then then the start button pad must be worn out.
I accidently hooked my RV up to a 240V plug and
After you have make our research and you have finalist the finding that getting to the door is the solution to the problem,
here are the solution below on how to go about the problem
On
these units they have a self resetting device that you will need to
activate this is done by unplugging the oven for at least one hour then
plugging it back in and wait for 5 min then press the normal cancel
button or you might even hear a click sound then you will be allowed to
unlock it okay and close the door hope this helps you out please rate
this solution it helps get better results for our customers like you
Thank you and thanks for using fixya.
Moved the mirco wave, then the only buttons that
i cant work out if its broken or not over the years i do remember seeing a sanyo microwave that would not cook untill the time was set though have not seen another since (cause its a silly idea) but try setting the time and it might work
User manuel #kor-861h
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
My Hinari Rota-Control microwave/convection/grill oven
the microwave CAN be used, but SHOULDN'T without the wave guide cover. You'll compromise the life of your unit by doing so. It allows the microwaves to penetrate to the food items while protecting the magnatron from grease and food splatter etc. Some covers are plastic, but can be replaced as well. In my experience as a tech. I can walk into a part's store and purchase a complete sheet of it (typically "6x9" or 7"x10" or there about...sheet's) and cut it to my desired fit, depending on the microwave. They do all get contaminated with food, grease over time unless diligently keep clean after every use.
Hope that help's. Thank's for visiting "fixya" and please take a moment to rate or comment on the info I provided for you here today.
Good luck.
macmarkus :)
Daewoo kor-861h, electrical smell and will not heat.
Turn if off, and leave it alone, remove it, if you can remove the unit, take it in for service, something is wrong if you smell electrical, most people for some reason can smell and identify correctly electrical or at least insulation burning smells, which means something is burning internally, not safe, fire hazard, unit needs to be repaired by qualified technician or replaced with new unit, take no chances, nothing you can do to repair this, could be a shorting transformer, or shorting power cables, but to attempt to trouble shoot this with email is a long shot, and depends on your experience expertize and testing equipment.
I wish I could give you a short easy answer, but the hazard and your safety is more important than a microwave.
Will
