20 Most Recent Daewoo KOG-867T Microwave Oven Questions & Answers
My daughter reheated a plate
its also in the ventilation. cover need to come off and basically needs to come apart. completely.
6/13/2017 2:54:37 PM • Daewoo KOG-867T... • Answered on Jun 13, 2017
0answers
0answers
Loud beeping when pressing time buttons...how do
Okay, well unfortunately your problem is either the touch pad or the control panel. If I was a guessing man I would lean highly towards the control pad. Now, either or doesn't matter because the cost to replace either of these parts usually runs around $175 -$200.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
5/5/2011 3:26:45 AM • Daewoo KOG-867T... • Answered on May 05, 2011
My deawoo kog 868 gsl micowave will no longer
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....Microwave Oven Basic Troubleshooting Tipsheatman101
11/8/2010 3:02:59 PM • Daewoo KOG-867T... • Answered on Nov 08, 2010
Lamp is glowing but no heating is taking place
Could be a blown internal fuse, or a burned wire, you can open it and look yourself, burned wires and fuses are usually easy to spot.
Best to have a repairman check it out if you are not into electronics. Make sure you get an estimate of repairs before you give the ok to fix it, it will most likely be cheaper to replace it due to labor cost,
9/23/2010 6:16:33 AM • Daewoo KOG-867T... • Answered on Sep 23, 2010
Microwave sparks inside oven in the area of the
If unit was run for long time with food on walls and not cleaned off, it is possible that the unit was burned in a spot where the food was and if there is metal frame under that part for the finish it will spark. Check closely for burns, if it is sparking due to that problem, junk it. It is a dangerous condition.
9/23/2010 6:05:09 AM • Daewoo KOG-867T... • Answered on Sep 23, 2010
It is not starting
Many possiblities, but first thing to check is door switch. Unit will not run if door is not closed. Door switch is safe feature. Remove outer casing and check to see if switch is broken or miss alined.
9/23/2010 5:55:02 AM • Daewoo KOG-867T... • Answered on Sep 23, 2010
I have a Daewoo microwave
Contact Daewoo Technical Assistance at 1-877-393-2725.
8/21/2010 12:20:58 AM • Daewoo KOG-867T... • Answered on Aug 21, 2010
Microwave not heating
it can be saved but get a quote from the shop first before proceeding and always evaluate it against the cost of a new one,
it could be the power supply has shorted but check it out.
7/29/2010 5:30:04 PM • Daewoo KOG-867T... • Answered on Jul 29, 2010
2answers
USER GUIDE INSTRUCTION MANUAL WANTED
www.genwi.com/read/5454578
6/3/2010 11:26:39 PM • Daewoo KOG-867T... • Answered on Jun 03, 2010
Daewoo Microwave KOG 867 T9-DEAD??
There could be a main fuse inside the unit. Mine has one that is ceramic, sort of like the old glass car fuses but ceramic instead of glass. Digi-Key has all kinds of fuses, www.digikey.com.
8/4/2009 8:20:10 PM • Daewoo KOG-867T... • Answered on Aug 04, 2009
Microwave Fuse
you can use any 8 amp fuse of that caliber even a bit larger if you had to.
Phil
5/18/2009 6:11:25 PM • Daewoo KOG-867T... • Answered on May 18, 2009
Daewoo KOG-867T Microwave Oven Logo
31 questions posted
Top Daewoo Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Microwave Ovens
Most Popular Question
  • Microwave Ovens
