20 Most Recent LG WM-1290FHB Front Load Washer Questions & Answers
I want a maual in english for my new washing
Try
mauritron.com
They have the world's largest library of
owners user instructions operating guides
and
technical repair schematics circuits service manuals
I'm not connected to them, just a satisfied user.
Also if you don't find your item in their listing then ask and they will get it for you
8/18/2011 2:16:19 PM • LG WM-1290FHB... • Answered on Aug 18, 2011
Made a loud clanking noise now wont pump out is a
Before considering the cost of a replacement pump follow my guidance notes through to the end first!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
6/27/2011 12:03:43 PM • LG WM-1290FHB... • Answered on Jun 27, 2011
Washing machine going through full
MOST LIKELY DUE TO A BLOCKED DRAIN PUMP....IT WILL NOT SPIN UNLESS THE WATER EVACCUATES ....CHECK THIS FIRST
2/10/2011 11:34:12 AM • LG WM-1290FHB... • Answered on Feb 10, 2011
What does UE fault mean? & what do I have to
UE means the washer has experienced a severe out of balance condition during the spin cycle, do not overload the washer and if necessary reduce the wash load size, distribute the items in the washer more evenly, this is especially true with heavy items like towels and jeans,.
2/5/2011 8:41:35 PM • LG WM-1290FHB... • Answered on Feb 05, 2011
Water won't drain. Cleared filter and hose still
BELOW ARE STEP BY STEP RECOMMENDATION ON HOW TO SOLVE THE PROBLEM OF YOUR WASHER THAT HAS FAIL TO WORK AS EXPECTED.
However,if you are having problems with either not draining or spinning, with your front load or top load washing machine, then you need to realize that they can be interrelated. Mostly in that if your washer is not draining the water it will not spin at all or at least not properly. There also can be others problems that will stop or slow down the spin, but the water not draining is the most common one.
So, if you are stuck with a washer that is full of dirty stinky water then here are some things to start checking.
First get that shop vac out or a bunch of rags and a bucket. The water needs to go. The shop vac will pull the water out the drain hose. Just remove it from the standpipe and place the nozzle in the hose and pull the water through the pump and into the shop vac. Of course if you cannot pull the water out this way, you already know that the pump is blocked or clogged, then just vac out all the water you can from the inside of the washer.
If all else fails, remove the front cover and take off the hose going from the tub to the pump. Yeah, water will go all over, but that is what the rags and bucket are for.
When the water is gone, you can then pull all the stuff out of the hose and pump, that are causing the problems. Most of these pumps are very easy to take apart and clean out. This will make sure that there isn?t anything inside the pump that can stop it. They are not very strong motors and something like a toothpick may stop it.
Now, where this get tricky is that there are sensors that check the water level and adjust the spin. If your water is not draining, your washer will not spin either.
For many washing machine problems that are drain and spin related, this simple cleaning will solve your problem. But there are other possibilities.
The lid switch is the old problem that keeps raising it?s ugly head on all washers. Bottom line here is that if the washer thinks that the door is open, the things don?t work right. Check out the door switch to make sure it is operating properly.
Make sure the new front load washers are on a good solid level surface. If the machine can move around then the sensors will often sense the movement and not allow the machine to reach full spin speed. Some manufactured bases may not be stable enough to give correct readings to the machine. If your washer is moving around, then fix that problem.
The timer can also be a problem. Many will wear out and then get to a point in the cycle, then not advance any further. Also the computer controlled sequencers can also get glitches and may need to be reset. You can check out the timer by manually advancing it, and the computer reset procedure will be in your manual that you received with your washing machine.
By going through this check list you can check out the problems that most handy persons can handle in the home. To make sure you have a the best chance at a trouble free washing machine, make sure that you do not leave anything et into your washer that will cause it harm or plug it up.
Good luck and thanks for using fixya.
1/26/2011 10:09:28 AM • LG WM-1290FHB... • Answered on Jan 26, 2011
IE error on LG intellowasher
IE = Inlet Error. Turn off supply valves to hoses and remove hoses from back of machine. Pull inlet screens out of the washer where the hoses were previously attached, clean them out, and re-install. That solves the IE problem about 95% of the time. (Usually, you only have to clean out the cold one.)
1/2/2011 6:28:09 PM • LG WM-1290FHB... • Answered on Jan 02, 2011
Washing machine shows se on display clicks then
check carbons in motor
6/28/2010 12:25:51 PM • LG WM-1290FHB... • Answered on Jun 28, 2010
How do you change drum bearing on lg wm-1290fhb
It is a difficult job in terms of handling! You require spanners and bearing puller. You require one extra assistance to hold the drum and pull from the front.
You have to change the full set of Bearings with same type and design. Check the bearing housing and the shaft before fixing new ones! Replace the water seals if any
4/6/2010 5:53:42 AM • LG WM-1290FHB... • Answered on Apr 06, 2010
Have Intellowasher WM1295FHB, when not in use the
sounds like your water inlet valve is bad
1/16/2010 12:59:54 AM • LG WM-1290FHB... • Answered on Jan 16, 2010
Lg intellowasher model wm 1290fhb door will not
  1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
  2. Press the Power button, while pressing the SPIN SPEED and SOIL LEVEL buttons. Then buzzer will sound twice.
  3. Press the Start/Pause button repeatedly with about 1 second interval until the lamps goes out.
  4. The washer powers off and unlock the door.
10/19/2009 1:53:22 PM • LG WM-1290FHB... • Answered on Oct 19, 2009
2answers
Will not drain. Gets to spin cycle and program stops.
check your lid switch
7/1/2009 9:45:38 AM • LG WM-1290FHB... • Answered on Jul 01, 2009
Lg intello washing machine
Any strange blue lights underneath, or noises or smells? I'm thinking it could be the motor brushes but it could also be that the belt has fallen off.Can you hear a whirring noise like a motor turning? Does the drum turn OK by hand when you open the door?
Hope this helps. If this "fixes ya", I'd appreciate a rating for my reply, If not, please add a comment with any extra info you have and I will try to think of comething else.
Thanks, D
7/4/2008 1:02:02 AM • LG WM-1290FHB... • Answered on Jul 04, 2008
Warning light
Go to:
http://www.lge.com/
Choose your country and download your free manual.
Cheers.
Satisfactory response? Please vote! :-)
3/2/2008 12:43:34 PM • LG WM-1290FHB... • Answered on Mar 02, 2008
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
11/20/2022 7:26:11 PM • LG WM Washing... • Answered on Nov 20, 2022
2answers
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
10/29/2018 1:31:58 PM • LG WM Washing... • Answered on Oct 29, 2018
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
12/27/2017 6:08:54 PM • LG WM Washing... • Answered on Dec 27, 2017
LG WM-1290FHB Front Load Washer Logo
28 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
ue fault mean amp
  • Washing Machines
