20 Most Recent LG LB1200ER Air Conditioner Questions & Answers
I have this model of air conditioner and it shuts
That is a possibility. Try feeling the cord when this happens, is it getting hot? If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
7/21/2017 10:42:52 AM • LG LB1200ER Air... • Answered on Jul 21, 2017
0answers
manual
0answers
My air conditioner is leeking
It means cooling coil and drain pan block. Remove unit and do water service.
12/8/2010 8:21:53 AM • LG LB1200ER Air... • Answered on Dec 08, 2010
2answers
The air conditioner has ice
its low on freon
10/23/2010 2:52:24 AM • LG LB1200ER Air... • Answered on Oct 23, 2010
My lg lb1200er is freezing up how do i fix it
Take the front off and replace or clean the filter. Get a soft brush and remove the lint from the coils. If it is severely dirty you can buy some cooling coil cleaner
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
7/16/2010 3:17:13 PM • LG LB1200ER Air... • Answered on Jul 16, 2010
I bought it yesterday and it turn on for about 5
mcdevito75 here, Check the owners manual for operation, then return the unit, fan motor could be faukty, most like ly some sort of relay is bad.
6/24/2010 12:41:54 AM • LG LB1200ER Air... • Answered on Jun 24, 2010
How does one install the still support?
mcdevito75 here If you mean the sill support for the window, Let your local A/C repair shop do it. Find one in your area online or in the yellow pages under A/C or appliance repair.
6/24/2010 12:25:06 AM • LG LB1200ER Air... • Answered on Jun 24, 2010
My lg a/c only blows air with no cooling what is
possible a tstat problem or compressor is not coming on...put your ear by the ac unit...if you hear a buzzing noise ,then shuts off,humming...compressor not coming on...
5/10/2010 2:55:23 PM • LG LB1200ER Air... • Answered on May 10, 2010
My a/c is not cooling , the cool air stops and the fan start
check your thermostat bulb it may be touching the coil of the unit
5/3/2010 5:09:58 PM • LG LB1200ER Air... • Answered on May 03, 2010
Air conditioner wont work after winter off
Make sure the filter is clean. When you remove the filter you should be able to see the evaporator coil. Make sure it's not clogged with dirt. If they are clean is the fan and compressor are running. If they are not working and with the cost of repair if no warranty. It's time for a new window unit.
4/19/2010 6:48:22 PM • LG LB1200ER Air... • Answered on Apr 19, 2010
Comressor takes 34ams when switched on what is the
The compressor is in a locked rotor condition..which means that it is trying to spin but cannot, probably because of a mechanical failure within the compressor...
You will need to replace the compressor, but for most window units it is cheaper to replace the whole unit...
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
4/15/2010 11:27:21 AM • LG LB1200ER Air... • Answered on Apr 15, 2010
Blowing circut
Well with air conditioners, you need to plug them into a circuit in your house that you will not be using for anything else, whether that be lights, computer, etc... because portable a/c systems like that can take up to 15 amps which is what the average circuit is designed for. If you do have it as the only thing plugged into that circuit in your home, then it could be that the unit is going bad and is drawing too much current, or the electrical system in your house is not operating correctly. To which if it is either the unit or your electrical system and not just an overload of appliances, then you'll need to either get the a/c fixed or replaced, or have an electrician come out and check out the system.
But check to make sure you don't have anything else on that circuit of your house other then the a/c unit.
7/19/2009 8:41:44 PM • LG LB1200ER Air... • Answered on Jul 19, 2009
Installtion Manual
Do you have power cord installed on the unit? If so then you will have to have a receptical near the unit. You set the unit in a window following the instructions set forth in the manual, then you find a electrical receptical near the unit and plug it in. Follow the instructions in the manual for desired temps and fan speeds. There isn't any other necessary connections as the unit is one piece based on the model number the thread was posted under.
3/21/2009 4:14:03 PM • LG LB1200ER Air... • Answered on Mar 21, 2009
My Lg split system air con spits water
Make sure the unit is tilted downward at the back. About 1" lower than the front is good. Even with a drain, the water will pool inside if it doesn't have a slope for drainage.
2/19/2009 8:23:47 AM • LG LB1200ER Air... • Answered on Feb 19, 2009
Installing a sump heater or cold weather use.
air conditioner can work at 0 deg C outside temp and you do not need a heater for compressor if is split system.
2/17/2009 9:06:55 PM • LG LB1200ER Air... • Answered on Feb 17, 2009
Unit dosent start up
if i dont get it figured out i will get the installer to take it back to the supply house .
1/16/2009 10:05:53 PM • LG LB1200ER Air... • Answered on Jan 16, 2009
Ac cools but fan keeps cycling
Does you unit allow you to set the fan to the on posistion all the time?
8/18/2007 1:49:41 PM • LG LB1200ER Air... • Answered on Aug 18, 2007
LG LB1200ER Air Conditioner Logo
23 questions posted
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • LG Heating & Cooling
Most Popular Question
air conditioner leeking
  • Heating & Cooling
