20 Most Recent
Freud FT750T Laminate Trimmer Questions & Answers
I want to rout out for hinges with a freud trimmer
You might be better off replacing the plastic base with a piece of 1/4" clear lexan (plexiglas). you'll be able to see through that.
Otherwise, you can make a simple jig that stops the trimmer at both ends (at the length of cut for the hinges) and controls the depth of cut by registering against the edge of the door. Make the jig base itself of 1/4' MDF or some such and longer than you think you'll need it to be so you have a way to clamp it or pin it down to the door.
If that sounds too complicated, try measuring the distance from the edge of the bit to the edge of the trimmer, in both directions, and marking the corresponding length away from the hinge position with a piece of blue masking tape or something, so you'll have an easily visible reference line when routing. You can mark it a little short and clean up the end of the cut with a sharp chisel.
Finally, run a test on a piece of scrap before you try to fit the hinge to your finished work.
Laminate Trimmers question
Router-neck cavities, pickup cavities; Laminate trimmer- saddle slots, smaller cavities, expanding existing pickup cavities on a finished instrument; Dremel- inlay inlay inlay.
Have a Freud FT 2000
If the router operates, and at full power, you could use an aftermarket rheostat for controlling the router speed. Rockler hardware sells one, others retailers may as well.
If this is not an option, a tool repair person (one of those old-timers...the "handy" ones that can improvise repairs and take pride in doing it) may be able to provide an option to keep it working for you.
Hope this helps.
Switch Freud j100
Hello I am a service dealer for Freud in Canada.
My Name is Larry Boccioletti
I have most parts in stock for most of Freuds tools.
I know Freud made a JS100 but not familier with a j100 If you can get me the serial number I would be happy to send you a quote.
My companies name is Halton Maintenance Centre
and my email is
[email protected]
Thanks Larry
