20 Most Recent
Simplex Kaba Ilco Unican 1011 keyless lock without key override Questions & Answers
Kaba lock won't open with code
Customer service can be contacted from this link:http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspxTech Support from this link:http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Is there a way to prevent theft of the Kaba Ilco
I can't help you directly, but I will steer you to further information.You will find a link to download the manual for your model on this page:http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.You can contact their customer service for more technical information.
Unican keypad door lock reset?
You will find a link to download the manual for your model on this page:http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.Good luck--and please provide feedback if this helps!
Door opens without any combination.
"If
your lock is opening on every turn of the knob or lever, except upon
entering a code, this may be a ZERO CODE. Before attempting to remove
the lock from the door, refer to the troubleshooting procedures outlined
at bottom of this document for a zero code symptom/solution
Solution: Follow the procedure for changing a combination except omit step 3 (do not enter
the existing combination)."
I excerpted the above from the full instructions on how to change the code. If you don't have them, got to this link:
and go across from L1000 to the last column, "Tips".
When you hover your mouse over PDF, two choices will appear; left click on the upper one, "Changing the code/..." to download it.
The
download will be a PDF file format. If you are unable to open it, you
will need to download and install Adobe Reader on your computer. There
is a link (Get Adobe Reader) at the top right of the literature grid.
When
you do get the download open, you will have the stepwise procedure and
illustrations necessary-but don't forget to omit Step 3, if you believe
that you have the ZERO code problem!
Model 1011... door opens without
"If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution
The download will be a PDF file format. If you are unable to open it, you will need to download and install Adobe Reader on your computer. There is a link (Get Adobe Reader) at the top right of the literature grid.
When you do get the download open, you will have the stepwise procedure and illustrations necessary-but don't forget to omit Step 3, if you believe that you have the ZERO code problem!
How do i change the
I'm not sure of your exact model, but I think you will find the information that you need listed on this grid chart:
You can cut & paste the link or type it into you browser's search bar.
Hover your mouse over the right-most column (Tips) for your model and you will pop up links for Changing the Code or Resetting the Code.
These are PDF files, requiring that you have Adobe Reader or equivalent installed on your computer in order to view them. If you're not able to view them install Adobe Reader from this link:
http://get.adobe.com/reader/
Code was forgotten and need
Go to the right-most column on the manual grid page, labelled "TIPS", and there you will find the files with the programming instructions.
As you will see, there is a reference in those instructions for the need for a DF-59 key. A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Also, there is a need for a spanner wrench. The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Kaba-Ilco Customer service can be contacted from this link:
Need to change the combination
Hi Don,
Got these instructions from: >>>> http://www.indra.com/archives/alt-locksmithing/hobbit.html >>>>
"Once you know the current combination, you might want to change it.
Instructions for doing this undoubtedly come with the lock; but it's real
easy. There is a screw in the top with a hex hole; remove this from the lock
body. Dial the proper combination, but don't move the handle. Press straight
down through the hole with a small screwdriver, until you feel something go
"thunk" downward. The lock is now in change mode. Reset the tumblers
[leftward twist], enter your new combination, twist the handle as though
opening the lock, and your change is now in effect. Re-insert the screw.
This does the following: The thing you hit with the screwdriver pushes the
tumblers down onto the locking bar [which is why the proper combination must
be entered], and disengages them from their idler gears. Button presses turn
the *idler* *gears* around, and then the opening action shoves the tumblers
back up to mesh with these gears in their new positions. A subsequent reset
mixes the tumblers up again to follow the new combination. This description
is admittedly somewhat inadequate; the right thing to do is take one of the
locks apart and see for one's self what exactly happens inside."
Hope this helps. If it does. I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Reset combation without a combation kaba
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
How do I change the
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
aspx?id=13
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Good Luck!
I have forgotten the code
aspx?id=13
You'll need Adobe Reader installed, as these are PDF files. The manuals show installation and reprogramming instructions.
You can also research other models of locks from this page.
