20 Most Recent Simplex Kaba Ilco Unican L1000 keyless lock Questions & Answers
I have a Unican 4000 series electronic door lever
Unican 4000 factory-default master code is 12345678
1/17/2019 5:32:32 PM • Simplex Kaba... • Answered on Jan 17, 2019
Simplex 1000
Try loosening the collar as much as possible and access the poke hole. I'm not sure how you managed to get the handle on, You might need to drill the collar, but if drilled while the collar is loose, the damage could be hidden. Good luck! Replacement collars are available, if all else fails.
7/22/2014 2:32:57 AM • Simplex Kaba... • Answered on Jul 22, 2014
0answers
2answers
Have simplex lp1000 keyless lock sytem is zeroed
"If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solutionSolution: Follow the procedure for changing a combination except omit step 3 (do not enterthe existing combination)."I excerpted the above from the full instructions on how to change the code. If you don't have them, got to this link:http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13and go across from L1000 to the last column, "Tips".When you hover your mouse over PDF, two choices will appear; left click on the upper one, "Changing the code/..." to download it.The download will be a PDF file format. If you are unable to open it, you will need to download and install Adobe Reader on your computer. There is a link (Get Adobe Reader) at the top right of the literature grid.When you do get the download open, you will have the stepwise procedure and illustrations necessary-but don't forget to omit Step 3, if you believe that you have the ZERO code problem!Good luck--and please provide feedback if this helps!
7/24/2013 11:51:39 PM • Simplex Kaba... • Answered on Jul 24, 2013
0answers
Green light on numbers door doesn't open
Customer service can be contacted from this link:http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspxTech Support from this link:http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
8/24/2012 3:59:11 PM • Simplex Kaba... • Answered on Aug 24, 2012
Where can we order the key to change to combo?
A Df-59 key can be purchased through this site:http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx Call them to order it @773-809-3667 Obviously it isn't really $0.Or try this source: http://www.ckilock.com/Mpage18.aspThe tenth item down is the key & spanner wrench for $9.
3/16/2012 12:08:03 AM • Simplex Kaba... • Answered on Mar 16, 2012
I was relocating a working
11/8/2011 7:02:31 PM • Simplex Kaba... • Answered on Nov 08, 2011
Unican LL1011 lock - the
I recommend that you contact Kaba Ilco with this problem--there may be nothing wrong with it at all, but you need an answer.Customer service can be contacted from this link:http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspxTech Support from this link:http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspxGood luck!
11/5/2011 7:55:16 PM • Simplex Kaba... • Answered on Nov 05, 2011
Simplex Kaba Ilco Unican  L1000 keyless lock  Logo
52 questions posted
Top Simplex Locks & Locksmithing Experts
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Simplex Locks & Locksmithing
Most Popular Question
simplex ll101126d41
  • Locks & Locksmithing
