20 Most Recent
Agri-Fab Agri - Fab Incorporated No. 45 - 0315 85lb Tow Spreader Questions & Answers
Setting indicator for model ct0025-85
Fixya does not have a source for replacement parts.
I recommend that you contact your nearest authorized service center, or you can download operators and service manuals directly from the Agrifab website by clicking on the provided link:
Downloadable Manuals
I trust this information proves useful.
Part number 008002
As fascinating as that is, I am unsure what you're needing help with.
I think the spreader I
Hello Assaidca,
I suspect it is about the same as any other comparable spreader. These things really are not calibrated to any universal standard.
You can download manuals directly from the Agrifab website however by clicking on the provided link and looking for your specific model number under the spreaders link:
I trust this information has proven useful.
Greetings: Have tried all kinds of sealants on
George,
Not sure what material your tank is but, since your'e in wisconsin there probably is a Menards somewhere by you. Get some Flex Seal tape.
Whether it is steel or plastic make sure it is clean. I've cleaned both with laquer thinner. Tape from the inside hopefully you can get to the inside and tape the outside. esp if the tank is over 10 gallons. If it's not clean it'll not last too long maybe a month or so. Tis super sticky so getting it on smooth can be a challenge. Warm tape helps alot.
you also may want to try flex shot Caulk. A good bead all around the screw will seal it. follow cure times though.
Enjoy todays weather!
best to you.
Gerardo palacios maldonado
Not real sure what you're asking for.
Need agitator for rugid spreader
Fixya has no sources for replacement parts.
Removing impeller mow n vac
Sounds like you need to contact your nearest authorized service center, or you can download operators and service manuals directly from the Agrifab website by clicking on the provided link:
Case ih tractor.mx135
your pto pump you have a good mower replace pump about 200.00 but think how old is it whats the possiblty with other stuff breaking down you and exspencive mower hard to make desission me i would have pump put on it also slight very slight be bad check valve but dont bet on it yea hold old how exspenssive is it worth it id replace pump my self it would be worth it
