20 Most Recent
Agri-Fab 175lb Agri - Fab Tow Broadcast Spreader Questions & Answers
Settings for scotts weed and feed 3 mph
I recommend that you contact your nearest authorized service center, or check the Scotts website for downloadable manuals.
I trust this information proves useful.
I bought a agri fab 175ib spreader and did not get instrution
Hello, Wharrelson65 -Unless another Fixya.com member has uploaded a manual for your model Agri-Fab spreader, right now, it is not available through Fixya.com.This is the link to the Agri-Fab company web page with manuals for their products:http://www.agri-fab.com/Utilities/Support/Manuals.aspx(Copy and paste the web address into the address box of your browser.)Note: I tend to try to find a company's home page and then try to find the link for Support, Customer Service, Parts in order to see if a manual is available to download.By the way, do you really want many others whom you do not know to have your email address? If not, I suggest you use the Edit feature and remove your email address from your question.
Greetings: Have tried all kinds of sealants on
George,
Not sure what material your tank is but, since your'e in wisconsin there probably is a Menards somewhere by you. Get some Flex Seal tape.
Whether it is steel or plastic make sure it is clean. I've cleaned both with laquer thinner. Tape from the inside hopefully you can get to the inside and tape the outside. esp if the tank is over 10 gallons. If it's not clean it'll not last too long maybe a month or so. Tis super sticky so getting it on smooth can be a challenge. Warm tape helps alot.
you also may want to try flex shot Caulk. A good bead all around the screw will seal it. follow cure times though.
Enjoy todays weather!
best to you.
Gerardo palacios maldonado
Not real sure what you're asking for.
I recommend that you contact your nearest authorized service center, or you can download operators and service manuals directly from the Agrifab website by clicking on the provided link:
Downloadable Manuals
Need agitator for rugid spreader
Fixya has no sources for replacement parts.
Removing impeller mow n vac
Sounds like you need to contact your nearest authorized service center, or you can download operators and service manuals directly from the Agrifab website by clicking on the provided link:
Case ih tractor.mx135
your pto pump you have a good mower replace pump about 200.00 but think how old is it whats the possiblty with other stuff breaking down you and exspencive mower hard to make desission me i would have pump put on it also slight very slight be bad check valve but dont bet on it yea hold old how exspenssive is it worth it id replace pump my self it would be worth it
