20 Most Recent LG LRMM1430 Microwave Oven Questions & Answers
Probably located inside the cabinet which will have to be removed. Be aware of dangerous, even exposed voltage present with cabinet removed.
LG LRMM1430... | Answered on Dec 29, 2017
If you go to LG's web site, or indeed most manufacturer's web sites, they have all of the details you require.
Happy browsing and I trust you will find exactly what you require.
LG LRMM1430... | Answered on Oct 30, 2010
take the screws out of the cover take it off can now access the light-check appliance store or hardware for the bulb.
LG LRMM1430... | Answered on Dec 22, 2009
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
LG LRMM1430... | Answered on Dec 12, 2009
I can help solve this fiasco , opening the unit while its running to stop it is not good to do because it will wear the door switches due to the load of power the unit uses while running the switches are not made to cycle the unit.
2nd there is radiation in the unit and around the unit while running so you should not reach in inside the unit immediately when stopped , give it a few seconds. Some commercial microwaves have an un-safe level of radiation 20+ feet away from the unit.
Most likely why they always get the order wrong.
Hope this helps.
Phil
LG LRMM1430... | Answered on Jan 07, 2009
First of all, microwave ovens do not emit ionizing radiation.
The only risk from any leakage is a burn.
Generally, microwave leakage only occurs when the door / door seal is loose or damaged or there has been an improper repair attempt.
You can select a model which lets you turn the beeper on and off by looking for that feature as you shop manufacturer Web sites, or in the store ask the clerk to pull the manual for you to examine, or contact the manufacturer's help center, support center, or FAQ.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. LG / Goldstar owner's manuals can be downloaded here.
If you're interested in other brands, please reply back and let me know. I'll be happy to post contact info.
LG LRMM1430... | Answered on Oct 29, 2008
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
LG LRMM1430... | Answered on Apr 28, 2008
What is it that you are losing ? You can set the power level by using the marked touchpads on the touchpanel, much like setting the volume on a TV. If you do not change the power setting and it is taking a long time to heat things or intermittently fails to, that is usually a sign that the Magnetron has reached its use by date and needs to be replaced. Not always an economical proposition unfortunately as spare parts are often exorbitantly priced.
Before removing the cover of the oven in attempt to carry out any maintenance such as replacing the Oven cavity lamp, make sure the oven is disconnected from the power point ! The voltages in a microwave oven ARE LETHAL !
LG Microwave... | Answered 2 days ago
turntable drive may be fouling on cabinet.
Take out the table and see if it is still slow. To centre the drive- take the panel off the bottom, you may have to cut the metal the first time
LG Microwave... | Answered on Aug 05, 2019
take cover off there are plastic catches who could have wear and tare
LG Microwave... | Answered on Jul 16, 2019
First, check your users manual for proper programming functions. Then either return the oven to the dealer for a replacement, if their policy allows it or contact a factory authorized dealer to service it under the warranty policy.
LG Microwave... | Answered on Jul 01, 2019
I would contact an LG service department and order one.
LG Microwave... | Answered on Jun 07, 2019
LG LRMM1430 Microwave Oven Logo
Popular Tags
22 questions posted
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
LG Microwave Ovens
  • LG Microwave Ovens
Most Popular Question
light bulb located
  • Microwave Ovens
