20 Most Recent
Intex 2500 Gallon Sand N Sun Pool Replacement Filter Pump Only Questions & Answers
Pool Pump - keeps getting air
It sounds like you might not be getting enough suction on your
pool filter. I would check all of the hose connections for cracks, loose fittings, etc. If you are getting any extra air, it will cause your pressure to decrease.
How to prime my Pool?
Prime is the term we use to state that the air has been mostly purged from the pump and the pump is moving water. When you have lost the prime, your pump is no longer pumping water through it. Sometimes it can be very difficult to regain the prime on the pump. This will tell you how to get the prime back in these difficult situations
We want intex IT-305WC software
1. Go to: http://www.intextechnologies.com/webpages/download-driver.aspx
2. Under the "Download Drivers" section, click "PC Web Cam".
3. Click on "Night Vision 500K (IT-305WC)"
4. Click "Win XP/Vista". This will start the download of the drivers for your web cam.
Lost my prime in my
if this is a flooded suction and when it turns on it keeps pushing all the water out faster than it is coming in you may have a pump that is too big for the size of the line coming in.
also look to make sure you have nothing plugging the lines going into the front of the pump.
Lost prime
Turn off the pump at the timer and remove the lid to your pump where you empty the debris from the basket. Get a hose or bucket and fill that resevoir with water and get the lid back on as quickly as possible. Turn on the pump and it should start to prime. On the filter, there is a air relief valve. Depending on the filter, it will pinch and twist, or there is a knob to uncrew. Doing that as the motor is running allows tbhe air that has built up inside to puge out. Once a steady stream comes out close the relief valve. May need to tryh it more than once.
What does U16 mean on my intex hot tub
limited info generic answer u code doesnt show for intex their codes usually start with E this is a manual that has the trouble shooting on page 20 ------- https://www.manua.ls/intex/purespa/manual?p=1 --------- and pg 13 has the codes
