20 Most Recent
Sonic 3 Wheel Scooter Questions & Answers
Battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Try to use scooter, clicking sound, then moves
How old are the batteries? When you connect the charger, if the charger indicates the batteries are charged within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced.
If the battery indicator on the scooter says the batteries are charged but the scooter still will not move, make sure the freewheel lever is in the drive position.
If you continue to have issues, contact your sales person or the manufacturer to schedule a service call.
The brake keeps comming on
mcdevito75 here, The brake cable could be stretched and appying the brake, check with Sonic online or call them for repairs.
How do I repair Sonic mobility scooter
You haven't described what the symptom is. You say you replaced
the batteries, but did you replace them correctly with the battery
wiring, making sure all connections are tight and turning on the
key..what does the battery charge meter indicate?
Pride Sonic Scooter
You can check the voltage going to the motors. The clicking you hear is the brake releasing. most likely, I bet water or something got on the controls and the signal is not getting to the controller. I hope its not the controller, they list for around $350.
What is ear wax and do I need to get rid of it?
Ear wax
always gets a really bad press but it's actually there to help the protect the
ear. It's produced in the ear canal and then slowly makes its way to the
opening. It should come out naturally by itself or with gentle daily washing.
When you use ear buds you just push the wax deeper into the ear and ultimately
that increases the risk of infection.
How many protein bars should I eat per day?
Go with whole food proteins or quality whey shake. Make sure you know what you are eating, Cliff is probably one of the highest rated ones, so two bars would be fine along with normal meals. Whey protein is a naturally complete protein, meaning that it contains all of the essential amino acids required in the daily diet.
Whey protein is a rich source of branched chain amino acids (BCAAs), containing the highest known levels of any natural food source. BCAAs are important for athletes since unlike the other essential amino acids, they are metabolized directly into muscle tissue and are the first ones used during periods of exercise and resistance training.
Whey protein provides the body with BCAAs to replenish depleted levels and start repairing and rebuilding lean muscle tissue.
How often should I visit my dentist?
Most adult and children visit the dentist for regular
checkups and cleanings every six months. People at greater risk should have
checkups more often.
