20 Most Recent
Bosch 3107DVS Electric Sanders & Polishers Questions & Answers
My Bosch 3107dvs
Drawing REF: http://www.ereplacementparts.com/bosch-3107dvs-0603310639-random-orbit-sander-parts-c-128_1044_1230.htmlTo remove the Dust Fan/Coupling Assy. I did the following: I disassembled the plastic housing, removed the Backing Pad Pos. 733 and Dampening Ring Pos. 51.It seems the Star Washer Pos. 29 holds Bearing Pos. 30. onto the armature shaft and the Coupling Pos. 27 seems to be stuck in Bearing Pos.29. I used a 30mm long M7 hex-head bolt and 11mm ratchet turning clockwise (std RH thread) to pull the Coupling and Star Washer off. Luckily, there was enough thread left in the coupling to do this gear-pulling action with the longer bolt. To remove the rest of the Fan Assembly I removed the 2 screws Pos. 43 holding the Brush Holder Assembly, Noted the position and removed the Spring Clip Pos. 32, then removed the Armature w/ Fan and Dust Fan/Coupling Assemblies. Firmly gripping the armature I was able to remove the Dust Fan from the armature by turning it clockwise (LH Thread).Now that I have removed the parts and believe I will be able to reassemble them, I have ordered a new Dust Fan/Coupling Assembly.I hope this helps someone else having a similar problem.
I replaced the rubber sanding pad but the screw
Some pads come with a new screw that has loc-tite on them. If you used the old screw when you put the new pad on, the loc-tite was probably dry and flaking off. Put a small drop of loc-tite on the threads, snug it down and let it sit over night and it won't come out anymore.
Sandpaper will not stick to pad
Use a quality adhesive backed sanding disk, and clean the pad area with isopropanol/alcohol. This should allow the adhesive disk to stick.
I recommend 3M adhesive disks.
