20 Most Recent
Sangean WR-2 AM/FM Radio Questions & Answers
No sound.
Read the manual. The radio may have been set to some defaults, although the time was not correct. When you started setting the time, it is possible that you should have run through the whole setup. For example some radios have different ranges for the FM bands: there is a Japanese band that starts at 76 MHZ, and ends at 108 MHz; there is the standard FM band from 88 MHz to 108 MHz; and a school band (I can't remember its range).
For AM the gap between neighboring positions may be set at 9 kHz or 10 kHz depending on the location (region or continent).
I suggest you get the manual and see if there is an initial setup procedure, then follow it.
Sangean radio
DT-210
Hi Fernando, you put the brand and model of your radio, but do not indicate what problems you have
Comment what you need, so I can give you some idea
I wait your answer
Greetings Franco Dosil
Hola Fernando, pones la marca y el modelo de tu radio, pero no indicas que problemas tiene
Comenta que necesitas, asi podre darte alguna idea
Espero tu respuesta
Saludos Franco Dosil
SANGEAN PRD5 AM TUNING IS OFF.
If you mean that gives odd number, I guess the tuning step is set on 9 kHz, try to press the band button longer than 2.5 seconds during the radio off, it can set the AM tuning step.
