20 Most Recent Motorola Mobility H680 - Headset - wireless - Bluetooth - black Questions & Answers
0answers
H680 not working
Be the first to answer 10/12/2017 9:21:04 AM • Motorola... • Posted on Oct 12, 2017Be the first to answer
I have a previous cellphone using a bluetooth but suddenly my cellphone was broken . now i have a new cellphone again and how to connect a bluetooth.
Motorola H680 Wireless Earset specifications here are the specs for your device, you can call your cust support for your phone provider or motorola tech support to learn how to use if you don't have and operators manual.
12/7/2015 2:06:57 AM • Motorola... • Answered on Dec 07, 2015
H680 bluetooth connected but can't talk or hear
Delete the pairing and connect again. Mark Motorola Support
2/12/2015 12:56:16 PM • Motorola... • Answered on Feb 12, 2015
Why can't I charge my headset
James Sorry you are having an issue. Have you tried another charger? If so and it still doesn't work. CONTACT US . If you have proof of purchase that it was purchased new less than year ago then we'll replace it. Mark Motorola Support
12/24/2014 6:53:22 AM • Motorola... • Answered on Dec 24, 2014
I have a H680 ear piece newly removed from box.iam unable to charge it although the red light comes on when placed on charger it fades away within seconds have left unit on charger for at least 3 hour
12/24/2014 6:52:14 AM • Motorola... • Answered on Dec 24, 2014
How topair my bt 03 with nokia310
they are different wireless frequencies and wont pare up you should get a Nokia product
6/12/2014 2:53:37 PM • Motorola... • Answered on Jun 12, 2014
0answers
How do I pair my Motorla h680 to my blackberry
In order to pair your headset with your phone, when you turn it on for the first time, its indicator light should be steadily lit in blue, thus indicating it is in pairing mode. If it has been paired to another device before, make sure that that device's bluetooth radio is turned off. If the light is not steadily lit, turn your headset off, wait for some 10 seconds, and turn it on again. Anyway, whilst its light is steadily lit, make you phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (indicator light starts flashing in blue). You see, the pairing procedure between any two bluetooth enabled devices should be performed just once. All subsequent connections between them should be achieved just by bringing they within each other's range, with their bluetooth radios turned on. At most, a simple press on the headset's call button should do.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Please, let me know if I can help you any further.
Regards,
Carlos
6/28/2011 3:39:57 AM • Motorola... • Answered on Jun 28, 2011
I am trying to pair
Regards, Carlos
6/28/2011 3:38:17 AM • Motorola... • Answered on Jun 28, 2011
I want to use my
It is hardcoded to '0000' (four zeros). Well, when you turn it on for the first time, its indicator light should be steadily lit in blue, thus indicating it is in pairing mode. If it has been paired to another device before, make sure that that device's bluetooth radio is turned off. If the light is not steadily lit, turn your headset off, wait for some 10 seconds, and turn it on again. Anyway, whilst its light is steadily lit, make you phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, it should enter the stand-by mode (indicator light starts flashing in blue). You see, the pairing procedure between any two bluetooth enabled devices should be performed just once. All subsequent connections between them should be achieved just by bringing they within each other's range, with their bluetooth radios turned on. At most, a simple press on the headset's call button should do.
Regards, Carlos
6/20/2011 12:37:50 AM • Motorola... • Answered on Jun 20, 2011
Dont no my passkey
Should be 4 zeroes, as in '0000'. No quotes. If it was changed, try holding the button down for 10 seconds and you should hear the unit beep when it has been reset to the default.
6/17/2011 9:30:23 PM • Motorola... • Answered on Jun 17, 2011
Motorola Mobility H680 - Headset  - wireless - Bluetooth - black Logo
77 questions posted
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Radio Communications
Most Popular Question
want use
  • Radio Communications
