20 Most Recent
Casio XJ-S31 Projector Questions & Answers
PROJECTOR PROBLEM Casio XJ 31
it wasn't able to go through cooldown mode. turn it on, power down and let it go through cooldown. does the light come on at all?
All the lights are on:
If you have the manual you can look at the back for troubleshooting. The problem or solution will depend on if the lights are blinking and what color they are. The manual can be found here. You will want the basic operations manual.
http://support.casio.com/manualfile.php?rgn=1&cid=007001005
I just had a XJ- S41 projector in for repair because it wouldn't power on. The power light was red solid but the temp and lamp lights were blinking red. Apparently a reset was needed, but I was told it was an internal reset that had to be done be a technician. I'm dubious of this info as I've seen some reset procedures listed on this site that may have worked, but I can't confirm as I sent it in. It cost $45 plus shipping to have Casio do this reset and there was nothing wrong with the projector or any parts replaced. Casio wouldn't tell me exactly what reset procedure was done and they will not let you speak with a technician or even try and get more info for you. Using their online repair service though was easy and swift. Just go to www.ecasiorepair.com.
I am using a casio
Make sure the laptop is set to enable the video to come out the external vga socket
Projector problem HELP!? my projector
Kindly get intouch with Cinesonic Audio Visual Pvt. Ltd. in New Delhi at 10/2, DLFIndustrial Area, Shivaji Marg, Moti Nagar,
New Delhi-110015
Contact: ' Board: +91-11-47424444 (30 Lines)'
e-mail: Robert@cavpl.com
For any problem related to Casio Projectors
PROJECTOR PROBLEM
it wasn't able to go through the cooldown mode. turn it on and power down, letting it go through the cooldown mode. does the lamp come on at all?
How do i do prime numbers on the NEWYES NY-991MS calculator and CTIFREE fx-991ES PLUS calculator?
The NEWYES NY-991MS and CTIFREE fx-991ES PLUS calculators do not have a dedicated "FACT" button like the Casio FX-83GTX. However, you can still find prime numbers on these calculators.To find prime numbers:NEWYES NY-991MS:Press the "MODE" button.Choose "PRIME" from the list of options.Enter the desired number and press "=" to check if it's prime.CTIFREE fx-991ES PLUS:Press the "MODE" button.Select "TABLE" or "TABLESET."Input a starting point and an ending point, then observe the table for prime numbers.Although the techniques may vary from those used on the Casio FX-83GTX, they prove to be effective for prime number calculations on the designated calculators.
