20 Most Recent
Magellan RoadMate™ 1212 Car GPS Receiver Questions & Answers
I was having problems with the car charger CA-051,
Using non standard chargers is probably the problem. If the battery has suddenly become sogged since using this charger then it may have done more damage than you want to know about.
Was it the correct polarity +ve Tip? was it the right amperage?
Magellan are specific in recommending you only use their charger and with reason, its correctly made for it.
You can try the new battery angle, but get advice on the charger.
As a small note.. Car chargers do NOT fully recharge batteries in GPS. Use an AC or USB charger. The car charger is a maintenance power supply. Always fully charge the unit prior to use and do not plug to car power until engine has been started.
These are standard rules with all non hard wired GPS and phones, ( but not always in the manual, have to have service and new sales someway!)
Please rate my help++++Thanks for using FIXYA
3/13/2011 3:17:50 AM •
Magellan...
Answered
on Mar 13, 2011
Are there free updates for
As a customer, through registering your product online and providing the device's serial number, you get one free update whenever you desire. After the first one, they are no longer free.
3/7/2011 1:43:40 AM •
Magellan...
Answered
on Mar 07, 2011
Screen broken what to do
Well you could take it in for a repair but you can buy a new one for $70 on amazon now, so it isn't worth fixing a broken screen. It would probley cost you more to have it fixed. Unless your kinda handy with tools you could always order the part from somewhere and try and fix it yourself. you really cant do anymore damage to it. It's how I learned out to fix things, just taking everything apart. My mother used to get mad at me though :-)
9/22/2010 12:47:39 AM •
Magellan...
Answered
on Sep 22, 2010
Broken screen Magellan roadmate 1212
Hi.
It is actually much cheaper to buy a new unit than to repair it.
It cost around $150 and above, depends on how crack it is and what model of magellan you're using.
8/11/2010 2:47:49 PM •
Magellan...
Answered
on Aug 11, 2010
I cannot get my gps to turn on
It is good that the temperature was at about 55 because these units will not charge at certain temperatures. I believe the lower limit for charging is the freezing point (32 degrees).
What about the power socket in the vehicle? Does it always have power applied, even when the ignition is not turned on? I know some vehicles turn OFF the power to the lighter and power sockets when the car is turned off.
Have you tried your car charger in another vehicle? Or have you tried another adapter, such as a cell phone charger, in the same power socket in the car? I am just trying to find out if there is power coming from the socket that you have picked. Also, try this:
* Press and hold the POWER button for 10 seconds.
* In the event the unit does not power on, reset it. The reset button is located on the bottom of the unit.
Let us know what happens.
8/6/2010 12:19:53 AM •
Magellan...
Answered
on Aug 06, 2010
Magellan 1212
With Magellan? You want free updates? If Magellan doesn't offer them then you are out of luck. At least on the legal software end of things. That's all I'm saying about that
4/3/2010 5:11:54 AM •
Magellan...
Answered
on Apr 03, 2010
I need to replace my screen on magellan roadmate 1212
Ok well i just did an exhaustive search, and I couldn't find anyone who even sells replacement screens as such, but they are actually 2 things, the screen, and the Touch screen on top. They can be real tricky, and fiddly to do, but it is not too hard if your careful and have all the tools and "Bits". My recommendation, is to send it back to Magellan, and get a "Quote" for repair, that way you can see to repair or replace, depending on cost etc, these manufactures are pretty fair with pricing.
3/25/2010 11:02:14 AM •
Magellan...
Answered
on Mar 25, 2010
I need argentina maps for GPS Magellan Rm 1212
amigo , yo tenia el mismo problema de mapas de argentina con un gps de un tomtom y otro con sistema wince ,luego busque y me recomendaron un servicio tecnico en cap fed ,ya me lo solucionaron me cargaron mapas de toda argentina,ahora quedo barbaro !! te paso la pagina ,espero que te sirva ,salu2
http://www.mapeo-gps.com.ar
3/19/2010 7:20:42 PM •
Magellan...
Answered
on Mar 19, 2010
