20 Most Recent
ASUS Motherboard, GeForce 6100, Athlon 64 X2, MATX, Max 4GB DDR2, PCIEX16, 2PCI, FENET, Vid, Aud, SATA3Gb (M2N-MX SE PLUS GREEN) Questions & Answers
How to connect usb wires
The following link will take you to the guide for your motherboard. In this guide, you will find instructions on how to connect the internal wiring.
Click here for manualRegards,
G33k
5/9/2011 5:22:45 AM •
ASUS...
Answered
on May 09, 2011
Motherboard drivers
Hello,thanks for using Fixya,
You can download the driversfrom ASUS WEB site. http://usa.asus.com/index.aspx
So please go there website
For download copy bellow thelink and paste on address bar.
http://support.asus.com/download/download.aspx?SLanguage=en-usSuppose, you need driver for, ASUS K8V-VM
Product =Mother Board
So Series= (Socket NO.eg. 754 etc.)
So Model= (Model no will be K8v-vm)
And please select the
O.S (XP / VISTA/ WINDOWS 7) version of the drivers that matches your P.C and search.
Now you can download easilyone after one. after download all the driver ,unzip the fie with winrar or zip.
Download the winrar free,
copy the link and paste onaddress bar.
http://www.filehippo.com/search?q=winrar
Install it .
Now right click on everydownloaded file and select EXTRACRT TO THE FILE FOR......,then create a newfolder with the with the driver file, you can install easily.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
1/20/2011 6:25:09 AM •
ASUS...
Answered
on Jan 20, 2011
Front audio not working in
Hi, friends ,
There is a usb socket, in your atx cabinet you need have. If you used old model cabinet cannot find the usb socket.Actully you need to purchase new atx cabinet.
Fit the usb socket to the mother board.
You can download manual from bellow the link, there is vedio bellow the web page.
http://www.ps2netdrivers.net/manual/asus.m2n/Hope it will help you.
12/20/2010 12:27:17 PM •
ASUS...
Answered
on Dec 20, 2010
No internet
It means you have no internet driver.
3/7/2010 11:43:17 PM •
ASUS...
Answered
on Mar 07, 2010
M2n-mx se plus with amd64 5200 automatic shut down
it might be a bios problem. Check that your harddrive and cdrom are set correctly too. For example if your harddrive is set to master and your cdrom is set to slave, change the cdrom to master and harddrive to slave and see if this helps.
3/16/2009 5:09:02 PM •
ASUS...
Answered
on Mar 16, 2009
When turn on pc it wont come out of sleep mode
make clear you have conected every cord onto its original position. be sure that cooling system works. some computers get stuck when they get too warm too quick.
2/3/2009 12:50:18 AM •
ASUS...
Answered
on Feb 03, 2009
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem:
1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in.
2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable).
3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues.
4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations.
5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors.
6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable.
7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility.
8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement.
Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
I am using an Asus Vivo mini computer approx 5 years old. Since December I often receive error message across top, "Microsoft Edge (not responding)"
Question edited for clarity and toss in a load of CAPS as needed.
Microsoft Edge is one of the worst browsers ever invented. It is flashy and looks pretty, but is not user friendly and is glitchy.
The most likely issue for that Error Message is your Internet Wifi signal dropping out. You can test this theory two ways.
Do you have a smartphone? Download the Free App Speedtest. When you get the Edge Error, whip out your phone and do a Speed Test. If it stalls or only returns a speed of 5 to 10 mbps, that is your issue.
Or Download Google Chrome which is FREE and a much more robust browser and easier to use. Keep both Edge and Chrome open, when Edge collapses, try to do things on Chrome. If Chrome works, then the issue is Edge. If Chrome also fails, the issue is your Wifi and Router. A Router reboot should be done about once a month.
Google Chrome Download - Download Google Chrome
google.comhttps://www.google.com
Continue your browsing experience from desktop to phone on Chrome. Download today. Now more simple, secure, and faster than ever - with help from Google built-in. Google Address Bar. One browser, all devices. Type less with autofill. Chrome support.
Download Now
Get a new and fast web browser. Download Chrome and start browsing.
