20 Most Recent Michele Mini Urban Diamond MWW02A000124 Watch for Women Questions & Answers
How do I change the stainless steel band the michele mini urban?
This takes some special tools to do. Take it to your near by Jewler and they can do it for you for Next to nothing.
9/30/2014 6:55:54 AM • Michele Mini... • Answered on Sep 30, 2014
2answers
What are the battery type (number) for michele watches?
The battery type differs, depending on the movement; what's the model number (on the caseback)?
9/7/2022 8:23:22 PM • Michele Watches • Answered on Sep 07, 2022
What type battery does michele coquette take how do you get the little screws off the back of the case?
FIXYA volunteers usually recommend using a jeweler in a local shopping mall who have the correct size tools and batteries for expensive diamond watches.
11/3/2018 9:10:51 PM • Michele Watches • Answered on Nov 03, 2018
Michele Obama mother to get 160000 pension every year for watching granddaughters
I would too, for that money.
10/27/2016 9:02:00 AM • Michele Watches • Answered on Oct 27, 2016
2answers
Can I replace the battery on my Michele watch
It's too expensive to change it on proper service or mall... you can purchase battery for amazon and change it at home, take a look here: Rayovac Batteries Lasts as Long Costs Less. I hope this helped. Cheers
1/28/2015 5:46:09 PM • Michele Watches • Answered on Jan 28, 2015
0answers
Collezio watch
Be the first to answer 1/24/2014 12:58:50 AM • Michele Watches • Posted on Jan 24, 2014Be the first to answer
0answers
0answers
I need to replace a
Seals in water resistant timepieces go bad over time. This exposes the movement to moisture, dust, etc. which can damage your watch, costing expensive service or a new movement. If the watch is worn in the water often, the rule is to replace gaskets every 12 months. If it is occasionally worn in the water, they must be replaced every 18 to 24 months. The seals must be tested properly under the appropriate pressure for the rating of the watch by submerging the timepiece in a pressurized chamber. If your watchmaker is recommending this for a watch rated WR, water resistant, or 30M / 3 BAR don't bother. This should never be worn in the water. If it is for a higher rating (50M/100M+ 5BAR/10BAR+) and you wear it in the water, it may be worth the investment.
1/19/2011 10:53:29 PM • Michele Watches • Answered on Jan 19, 2011
The red stone on the
better to take it to a service man
12/13/2010 6:57:48 PM • Michele Watches • Answered on Dec 13, 2010
I need a new battery
Most digital watches have "standard" batteries. Invariably all batteries have a number on them.All watch battery stockists have "equivalence lists" so that irrespective of brand of battery a "generic" battery of the same dimensions - diameter and thickness ( and voltage) can be found from a "stocked:"range.e.g.a battery that is 6.8mm diam and 2.6mm thick is variously known as a SR626SW, SB-AW, 280-39, RW329 or a 606 or a D377 - dependng on the "brand" of battery - It's common name is a 377 battery - and it will fit in - and work
8/30/2010 7:04:20 AM • Michele Watches • Answered on Aug 30, 2010
Michele Mini Urban Diamond MWW02A000124 Watch for Women Logo
2 questions posted
Top Michele Watches Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you a Michele Watch Expert? Answer questions, earn points and help others
View Most Popular
Michele Watches
  • Michele Watches
Most Popular Question
change stainless steel band michele mini
  • Watches
