20 Most Recent Michele CSX Diamond watch Questions & Answers
2answers
My michele watch chronograph is stuck
Have a watchmaker fix it...there isn't anything you can do.
4/9/2019 5:53:55 PM • Michele CSX... • Answered on Apr 09, 2019
0answers
0answers
Change day
Be the first to answer 9/9/2013 5:46:25 AM • Michele CSX... • Posted on Sep 09, 2013Be the first to answer
Am I able to buy 3 links for my Michele watch?
yes contact the manufacture / google it. call with model number.
2/2/2012 3:41:58 PM • Michele CSX... • Answered on Feb 02, 2012
I didn't wear my Michele CSX 36 w/ diamond watch for a few days..When I went to put it on the time was wrong. So I tried to correct it and now it has not kept accurate time w/in a 24 hr period. Fo
I am pretty 100 percent sure that Michele CSX 36 diamonds only comes with a swiss quartz movement not an automatic movement. So the problem seems to be that the battery is dying and need to be replaced. Stopping and going is usually a sign of a battery dying in a swiss quartz movement. So it should be nothing major and just a battery.
1/28/2012 8:47:07 PM • Michele CSX... • Answered on Jan 28, 2012
MICHELE CSX HAND ALIGNMENT
You don't say if your "CSX" is a battery powered watch or a mechanical or windup type watch. The solution for a mechanical watch is take it to a watchmaker. If it is a battery powered watch you may be able to do it yourself. Not all work the same way so without knowing what a "CSX" is I will give you one way to try. Pull the crown out two clicksHold the lower button in until a hand moves.You have now selected that hand to adjustUsing the upper button now, press and adjust the hand until it lines up with 12Now hold the lower button againAnother hand should moveUse the upper button to adjust this hand to the 12 positioncontinue this until all the hands line up with 12Press the crown in and press the upper button,the chronograph hands should startPress the upper button again and they should startPress the lower button and they should all go to the 12 o'clock position
10/21/2011 7:05:51 PM • Michele CSX... • Answered on Oct 21, 2011
2answers
How do i get the day to match the date
Here is step by step instruction as well as the picture.
Please click on the link
http://www.michele.com/wcsstore/Michele/images/instructions/michele_instructions.pdf
I hope this will help you resolve the issue.
Thank you for choosing fixya.
10/21/2011 6:44:45 PM • Michele CSX... • Answered on Oct 21, 2011
54 questions posted
Top Michele Watches Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you a Michele Watch Expert? Answer questions, earn points and help others
View Most Popular
Watches Michele
  • Watches Michele
Most Popular Question
didn 39 t wear michele csx 36 w diamond
  • Watches
