20 Most Recent
Swatch Irony watch Questions & Answers
My Swatch Irony watch has
Thank you for contacting Fixya,<br />
I would have the battery checked again. Sometimes batteries in stores can be past the extended life of battery. Otherwise could be a number of issues. Has it been around water? Dropped? Could need cleaning. In cases of most watches, like Swatch, the cost to have repaired may exceed the watch. <br />
You can contact Swatch at:<br />
<a href="http://www.swatch.com/zz_en/shop.html">http://www.swatch.com/zz_en/shop.html</a>
Set the date in analoge
To set the date is a easy operation.Just pul one position the krone out une position and rotate down.See the tutorial and do the same thing.
http://www.youtube.com/watch?v=9feU33jbgJQ&feature=player_detailpage#t=80s
Swatch Irony Battery replacement will not work
mcdevito75 here, I am thinking your watch ran fine before the battery change. It sounds like the new battery is not makeing good enough contact, you can try, removeing the battery and cleaning the contacts in the watch carefully with a Q tip, dip the Q tip in anything containing alcohol cologne, rubbing alcohol, perfume wet the Q tip good, then sqeeze most out of the Q tip as not too saturate the battery contacts, also clean the battery itself, the oil on your fingers could give it a poor contact on the watch. The stop watch section doesn"t take as much battery power as the second hand. You may also be able to jump start your watch also, You"ll need a needle and a magnifier glass, With the back off your watch, right in the middle of the movement, just below where the stem (winder) goes, you"ll just see part of a little gear, this is the hour hand gear, see if you can gently move that gear just a fraction, place the needle between the teeth of the gear and try to move it as gentle as possible then se if the gear will move on it"s own., be very carefull with the movement. Swatch watches are collectables. If you don"t feel comfortable doing the above, look for a small watch repair shop in your area for help.
How to remove the back cover of the swiss army
The back will either have a small slot on one edge to pry it off or indentations around the perimeter for a case wrench to unscrew it. Specialized tools are used to avoid scratching the case. You best bet is to take it to a watch shop and let them do it. Most places charge between $3 - $8 to properly do it without damaging the case and they should also change the gasket to maintain water resistance if so equipped. Once you have it open you risk damaging the movement as you change the battery. It's not that it's a tricky procedure but you can easily damage something that will cost a LOT more than $8 to fix if you don't have experience.
I need to reset the hands
Assuming you want to reset the zero posistion of the chronometer (stop watch) hands...
On my watch I can adjust it by doing the following...
To reset the microseconds hand / top right
1) Pull the center knob full out (2 clicks)
2) Press the bottom push button to adjust the hand
To reset the seconds hand / middle
1) Pull the center knob a full out (2 clicks)
2) Press the top push button to adjust the hand
To reset the minutes hand / top left
1) Pull the center knob out half way (1 click)
2) Next press the bottom push button to adjust the hand.
Once all hands are reset, push the center knob back in fully...done
How can i fix my swatch if it is changing the day at 1:30 am instead of 12 am
i'm not sure if your swatch is simply clicking over at 1:30am, or if it is actually starting to switch over much earlier, and then completing the switch at 1:30.
the latter is how most watches work...especially my beloved seiko SKX diver automatic. the switchover begins prior to midnight, and ends after midnight...sometimes starting the slow turnover as early as 11:30pm in some watches and ending at as late as 1:30.
however, if this is not the case with you, and it's just flipping over late, i don't know what can be done with something like a swatch. you don't mention if it's an automatic or quartz, but literally most swatches are NOT built to be repaired. they were conceived as a throwaway watch when done with, and the cases are not made to be opened for repairs.
they have become such a cult item that if you look ******* google you can find companies or people who have learned how to open a swatch without destroying it, can source parts, and can fix/repair the watch. but it's not an easy slam dunk deal. it's different with each model.
so, with a timepiece like a swatch, with its unique character of having an endlife, kind of like a replicant from Blade Runner, you will need to likely accept what you have bought with its limitations, and the one you've mentioned is minor compared to the watch just breaking and needing to be thrown out or put in a drawer.
the swatch definitely has limits set out by its very concept. and to go back to the movies, as Dirty Harry once said: 'A man's got to know his limitations'.
that goes for watches too.
cheers.
How do I set swatch watch stycs598
Gently pull the middle button, (or 'crown'), outwards away from the side of the watch. It won't move very far but if you do it slowly and gently you should feel it move 2 clicks or 'notches'. Pull to the first 'notch' for the Date settings and the second for the Time settings. For the date twist one way for the day of the week and twist the opposite way for the date number. Pull the crown out to the 2nd 'notch' and you can move the hands to the correct time. Push the crown all the way back In when you have finished doing any of these settings.
Water (vapor) under the crystal
Water condensation on the inside of your watch crystal means that moisture has entered your watch, most likely through the hole in which the setting crown/stem is fitted, or, possibly, through the door of your battery compartment. It's usually easier for water to enter a watch then to leave it again. Water inside a watch can quickly corrode delicate parts, causing erratic timekeeping and premature failure of the watch, so you'll want to get it out of your watch as quickly as possible.
Fortunately, it's not that difficult to get moisture out of a Swatch. Pull the crown out into the time setting position and remove the back battery hatch. Then, turn the watch face down and leave it in the sun for a few hours. If you're worried about dust and/or rain getting into your watch, leave it inside a parked car that's in the sun--that will actually speed up the drying process, as car interiors, with the windows closed, quickly heat up far beyond outside ambient temperatures (except in winter). If it's dark outside, you can accelerate the drying process by using a hair dryer set to low / medium heat and heating the crystal gently until the moisture has evaporated. You don't want to heat the crystal too much or else it may start to melt or crack.
Once the water is out of the watch, close up the battery compartment and update the time/date for your watch. You should be good to go, as long as you try to keep your watch dry when doing things like washing hands and the like. If you had been doing so, it's also time to stop wearing your watch when you shower, wash your car, or engage in other activities where the watch is exposed to a lot of water.
