20 Most Recent
Nostalgia Electrics Retro Series 0.9 CF Microwave Oven in Red Questions & Answers
My microwave will not heat up anything! all the
Sorry no answer, but I JUST bought mine and it was working just fine until this morning. Turns on, times down, turntable works, sounds like it's working, won't heat a DAMN glass of water!!! We'd both like help please
1/8/2023 11:44:24 PM •
Nostalgia...
Answered
on Jan 08, 2023
Hello my Teka MCX 45.1 BIT microwaves start button not appearing?
Microwaves generally last about 2000 hours before losing power. Here are some basics to try: Make sure the power plug is securely plugged into the wall outlet. Listen for an audible click when you close the door. Unplug it, wait 30 seconds, plug it back in (this may reset it). If the start button is then not appearing, there may be a problem with the touchhpad or control panel. Teka's customer service:
https://www.teka.com/global/support/
What cause the high voltage fuse to damage
Based on the fact it is not said where it is used or how it blows i.e. does it blow as soon as power is applied or does it blow after a few seconds? In the first case you probably looking for direct short while in the second case a faulty item that is becoming defective when energized or hot.
My bowl is stuck on
I have the same problem now its the second time it got stuck. The manuals say not much. :(
