20 Most Recent
Nostalgia Electrics RMO-400BLK Retro Series .9 CF Microwave Oven, Blk Questions & Answers
Hello my Teka MCX 45.1 BIT microwaves start button not appearing?
Microwaves generally last about 2000 hours before losing power. Here are some basics to try: Make sure the power plug is securely plugged into the wall outlet. Listen for an audible click when you close the door. Unplug it, wait 30 seconds, plug it back in (this may reset it). If the start button is then not appearing, there may be a problem with the touchhpad or control panel. Teka's customer service:
https://www.teka.com/global/support/
What cause the high voltage fuse to damage
Based on the fact it is not said where it is used or how it blows i.e. does it blow as soon as power is applied or does it blow after a few seconds? In the first case you probably looking for direct short while in the second case a faulty item that is becoming defective when energized or hot.
My bowl is stuck on
I have the same problem now its the second time it got stuck. The manuals say not much. :(
My wave guide is terribly burnt. Can it be fixed or do I need a new microwave? Hisense- Model no: H25MOMS7H.
If your microwave's waveguide cover is severely burnt, it is generally recommended to replace it rather than repair it. The waveguide cover is designed to be transparent and protect the antenna or magnetron from food splatter and grease. To replace the cover, follow these steps:
1. Identify the replacement part number from your microwave's user manual or contact the manufacturer.
2. Order the part from the manufacturer, authorized dealers, or reputable appliance parts suppliers.
3. Turn off the microwave to ensure safety.
4. Remove the old waveguide cover and secure it using screws or clips.
5. Place the new waveguide cover in the same position and secure it using the appropriate screws or clips.
6. Test the microwave to ensure the new waveguide cover is in place and functioning correctly.
Replacement is crucial as a burnt or damaged waveguide can affect the microwave's performance and cause further damage to internal components. If you have any doubts or are uncomfortable with the replacement process, seek professional assistance or contact the manufacturer's customer support for guidance.
