20 Most Recent
Promise Ultra133 TX2 ATA Controller Questions & Answers
Conflict between Promise Ultra133 and SATA RAID controller
Check that your RAID controller and onboard SATA controller aren't in a compatibility mode. You can put them in this mode while you have no SATA driver installed in Windows.
This tricks Windows into seeing the SATA drives as regular IDE drives. Your BIOS then has a spasm when it see's another IDE controller there, and just uses the card instead.
Make sure the SATA drivers are installed first, otherwise anything SATA will stop showing up. (and your Windows just won't boot if it's on a SATA disk and you take compatibility mode off) =-]
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Bios problem
if worse comes to worse. put the hard drives on external 3.5 cases.. i had this card i did a firmware update on it for some cdrom issue. bought it in 2000
SBCglobal NuMbER {1=855=536**5666}#O@ ARKANSAS
Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
9/18/2019 4:39:16 PM •
Promise...
Answered
on Sep 18, 2019
