20 Most Recent
Microsoft Get Genuine Kit for Windows XP Professional Questions & Answers
Need password for Microsoft 10
You shouldn't need any password for Windows 10. If you are getting that you have downloaded the wrong version. If you are a Windows 7 user make certain you are only downloading the version of 10 that matches the Windows 7 you currently have. So if you have Windows 7 Home download Windows 10 Home. If you try and download any other type IE Professional - then you will get asked for a password. Which you will have to pay for from Microsoft.
Windows XP is not compatible with Windows 10. If you are using a computer that uses Windows XP and you can't upgrade your computer to Windows 7 or 8, then you will NOT be able to run Windows 10 on it.
When I try to brows google or gmail of facebook it
First, go to a Fixya section which more closely matches your problem. This is the Cars and Trucks section.Next, try Web searches for current scams using "unlocking codes" or software counterfeiting password scams.Your computer Manufacturer may have Tech Support or have Software support for the operating system they installed in your unit.
I am a victim of software counterfeiting
Well I had tough time finding soloution for it, but found a way after going through many blogs, its obvious that we are not using genuine MS OS, but we can go for it to solve the problem altogether .The following steps are used to get rid of the Messagge "you are a victim of software counterfeiting" nagging at the desktop.Which happens to be outcome of Automatic updates "turned on" when you are conneted to internet.It worked on my computer and I dont have the message popping up anymore.I hope that you will find much help.
STEP 1
Turn off Automatic Updates
Clilck on START ->Settings-->Control panel ->Automatic updates (Select TURN OFF)
STEP 2
Goto My computer C drive select the folder ->Windows-->system32-->chek for a file WGATRAY.EXE (there r similar dll files named WGA * make sure ur selecting the correct one. The Icon is star shaped, similar to notification icon.This ICON would't delete).
STEP 4
Rename the file deleting the .exe extension and adding some number to filename (ex:Rename WGATRAY.EXE to WGATRAY22) make sure u remember the file name after renaming.
STEP 5
Delete the Renamed file (ex: wgatray22).It falls in Recycle bin.
STEP 6
Reboot the computer.
And chek there will be no message popping up on desktop !!!!
u might experience Black background screen, u can change the themes of your computer to different one from Control panel ==>display.(OR) Right click on Desktop-->properties-> themes
(I myself turned on Automatic updates to see any changes , it did not bring up any mesage later but not sure in future.)
Hope this article is helpful to folks!!!
Genuine software
format the system and off the automatic update--
1.go to task manager ---process ---wgatray.exe remove it
2. go to safe mode wgatray.exe from c:\windows\system32
3.delete wgatray from c:\windows\system32\dllcache
type
regedit in cmd
remove wgalogon
Software counterfeiting
The problem can be solved with either purchasing a good copy or call the customer support service they can issue you another license. This will solve the problem of a bad license. John
I am sick of seeing
You are getting this message because Microsoft has detetected that you do not have a genuine license key for the PC or Laptop you are now using.
If you legally got this software, it is likely that you are trying to use it on another device and have now exceeded the number of computers you can have wth this OEM volume license.
If you think that you are legally entitled to use this software on this specific computer, then contact Microsoft Help desk and they will assist you in solving this issue.
Hope my explanations help you understand your situation ...
I am the victim of
i am the victim of microsoft genuine software counterfeiting.....can you please give me the solution
How can i remove the remove Genuine microsoft
.Net framework has nothing to do with that - it's a base thart other programs use, needed on your laptop.
The genuine warning comes up when windows thinks you are running a pirated OS - it can't be removed or disabled and it malfunctions are notorious.
You should reinstall using the recovery disk that came with the lapto and the problem will go away.
I have problem of software
Purchase a "Windows Vista Upgrade" or "Windows 7 Upgrade" disk, and install the newer version of Windows, to replace your current non-genuine version.
