20 Most Recent Raymarine Linear Feedback Unit For Outboard Engines, 12" Questions & Answers
2answers
Why does my50 hp merc run ut of fuel after about 20 min bulb gets soft ?
You may have a minor air leak in the fuel supply system. Over a period of time, the system draws in enough air that the pump looses it's prime.
3/3/2015 12:28:20 AM • Raymarine Linear... • Answered on Mar 03, 2015
2answers
I have a 1990 90 HP mercury outboard. It is rough idling and surg
I have a 90 hp force ob. when i run it with the ears she runs fine lets me bring the throttle all the way up. when i but it in the water thru the wake area i can do 4 mph once i'am out of the wake area and give it the gas she dies, any ideas
10/13/2013 2:05:51 AM • Raymarine Linear... • Answered on Oct 13, 2013
I have a 4o hp outboard marinier and when u give
It is most likely a damaged prop. If the gear shift handle is steady while it is slipping, Your prop needs to go to the shop for a re hub. Take a punch and mark the center of the prop (the hub) ,then mark the blade of the prop in alignment. Try it out and see if the marks still line up. If they have moved- the prop is bad.
8/1/2012 3:41:06 AM • Raymarine Linear... • Answered on Aug 01, 2012
Lost keys to my pontoon boat put a new switch in
You need to get the 6 pin switch. Then find out what type ignition you have as they all wire to the 6 pin switch different.A cdi ignition will need to be grounded out to quit. As a magneto. The battery powered cd ig will need to break the positive power to quit, as will straight battery. If you wire it wrong- you could be looking at $300 or more switch box.Your 3 pin is most likely a generic battery ignition car switch which has a power/ignition/starter. set of terminals.
8/1/2012 3:36:19 AM • Raymarine Linear... • Answered on Aug 01, 2012
My 1988 johnson outboard 50 hp motor dies off when
Any fuel filters? If the fuel line is old I would replace it due to the ethanol in gas. If not that then clean the carburater, high speed jet may be clogged.
10/12/2010 2:02:48 AM • Raymarine Linear... • Answered on Oct 12, 2010
1990 90HP Mercury. When running motor ashore with
Replace water pump to be on the safe side.
10/12/2010 1:50:25 AM • Raymarine Linear... • Answered on Oct 12, 2010
I have twin 2004/2005 90
sorry but its a carb ,i nearly bought a honda engine with like this but i plumped for the mercury with fuel injection ,you will need to remove the carbs and put them on the kitchen table and strip and clean them right out then rebuild and refit and get the mixture on the idle right ,fuel to air mix should be about 14 to one ,this is done on a jet on the side which i suspèct is corroded and blocked ,then their should be a air bleed screw as well ,if this all to complicated which it is then get the man from the dealer to do it for you .you have a idle jet .compound jet and a main jet and trust me if you do not know then dont play with it .On my single outboard i rewired it so when its warm i can put in drive and start in drive to stop wear on the dog clutches ,dont like changing them either as they are expensive and difficult when engine is used in salt water and the bolts corrode ,also change oil regular in the bottom diff unit ,i do mine every year when i paint the bottom ,and i use car diff oil EP90 as that mercury stuff is so expensive and i begrudge paying for it when i have drums of oil here in the yard ,i also use the car spark plugs and oil filter for a panda .When you are moored up and not using the engines take the covers off and in the bottom of the float chambers are drain screws ,so when parked up just drain the carbs of fuel and then they will not clog up with that white powder where the petrol dries out
7/24/2010 6:39:33 AM • Raymarine Linear... • Answered on Jul 24, 2010
1987 Bayliner capri 85hp force starts and idles fine,after it
if u have a seperate onboard tank i bet its the vent valve is closed
7/20/2010 3:44:23 PM • Raymarine Linear... • Answered on Jul 20, 2010
My old feedback unit has a red,white,and black
If you run the wire to the CPU the color code is on the CPU. If it is a ST5000 series product the wire would need to be run to the back of the control head. Both the CPU and the control heads are clearly marked for the color codes.
6/14/2010 4:28:25 PM • Raymarine Linear... • Answered on Jun 14, 2010
My outboard wont start
if you have spark and fuel it should atleast fire when you spray fuel in the carbs. if your spraying it just into the air intake it may not be making it to the intake manifold. have you checked the fuel pump? you also need to check for the possibility of a air leak in the fuel system causing the motor to fail to run because it has a very lean fuel mixture. check all fuel lines, fuel tank, couplers and carb gaskets. if you havent take the air intake cover off and try spraying some wd 40 or other mildly flammable product and see if the motor will fire that way. its likely the fuel tank or fuel lines are the problem from my point of view. good luck.
5/30/2010 10:19:59 AM • Raymarine Linear... • Answered on May 30, 2010
15hp mariner only idels with the choke out
Hello! Draining the tank was a necessary move. You will need to remove carburetor, take it apart and clean it. It is a an easy job; they are quite simple. All you will need is a new gasket and you can make one. If the fuel filter is inside the gas tank, take it out and clean. If it's an inline filter you can replace it with an ordinary lawnmower inline. Use a carburetor cleaning solution. When you reassemble, lube the choke so it moves freely. Also clean the gas line.
Dry all spark generation parts. A hair dryer works well.
If you require more assistance don't hesitate to send a comment.
Guru......................saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
12/20/2009 9:48:34 AM • Raymarine Linear... • Answered on Dec 20, 2009
Need firing order for a 86 chrysler outboard boat engine
Firing order 1 2 3 is common on most three cylinder outboards. 1 3 2 is the only other combination.
7/26/2009 2:21:16 AM • Raymarine Linear... • Answered on Jul 26, 2009
The Raymarine ST8002 Smartpilot the unit powers up but does not work when the auto mode is selected. The hydraulic motor does not engage when a course is set. What could be the source of the fault?
According to a post on the Raymarine forum, this error message could indicate an issue with either the steering, the drive unit, the rudder reference unit (if fitted), or the course computer . The post suggests a few tests that you can do yourself to figure out which item is causing the issue. I suggest that you try the following steps: Check the connections between the ST8002 SmartPilot and the other components of your autopilot system. Check the calibration of the ST8002 SmartPilot and the other components of your autopilot system. Check the hydraulic fluid level and the hydraulic pump pressure. Check the hydraulic pump motor and the hydraulic pump solenoid valve. If none of these steps work, I recommend that you contact Raymarine customer support for further assistance.
11/20/2023 9:03:39 PM • Raymarine... • Answered on Nov 20, 2023
How do I connect my garmin 741sx with my raymarine St 4000 with nmea 183
To connect your Garmin 741sx with your Raymarine ST 4000 using NMEA 183, you will need an NMEA 0183 interface cable to connect the two devices. Here are the steps to follow:
  1. Obtain an NMEA 0183 interface cable that has the correct connectors for your Garmin 741sx and Raymarine ST 4000.
  2. Connect one end of the NMEA 0183 interface cable to the NMEA output of your Garmin 741sx.
  3. Connect the other end of the NMEA 0183 interface cable to the NMEA input of your Raymarine ST 4000.
  4. Configure your Garmin 741sx to output NMEA 0183 data. Refer to your Garmin 741sx manual for instructions on how to configure NMEA output.
  5. Configure your Raymarine ST 4000 to receive NMEA 0183 data. Refer to your Raymarine ST 4000 manual for instructions on how to configure NMEA input.
  6. Once both devices are configured, the data from the Garmin 741sx should be transmitted to the Raymarine ST 4000 via the NMEA 0183 interface cable.
2/23/2023 5:01:41 PM • Raymarine... • Answered on Feb 23, 2023
Raymarine C70. Como cambiar la pantalha de modo diurnos a noturno ?? en el Raymarine C70.
Question edited for clarity.Question moved from Cars and Trucks to Raymarine.Adjusting the display lighting The display has two distinct color palettes, for day and night operation. You can alsomanually adjust the backlight level.Note: The display lighting is a local setting and will therefore only affect the individualdisplay on which you are working.Day/night operationTo select the day/night mode of operationhttps://www.manualslib.com/manual/138190/Raymarine-C-Series.html?page=30#manual
8/3/2022 6:36:50 PM • Raymarine... • Answered on Aug 03, 2022
I want to mount a sonar transducer for my raymarine dragonfly-4 on my 16 foot aluminum boat where do I mount it Thank you
on the transom outside of the boat silicone the bolt holes
10/29/2021 12:36:07 AM • Raymarine... • Answered on Oct 29, 2021
Raymarine Linear Feedback Unit For Outboard Engines, 12" Logo
Popular Tags
17 questions posted
Top Raymarine Boating Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
View Most Popular
Raymarine Boating
  • Raymarine Boating
Most Popular Question
  • Boating
