20 Most Recent
Cardo S-800 Bluetooth Headset Wireless Headset Questions & Answers
How to set up to iphone
First open the blueooth setting on the iphone
start the bluetooth service(turn on) on the iphone.
Power on the bluetooth headset.
search devices in iphone, wait till it finishes searching, until you see the name of your bluetooth headset.
the headset would blink two or three time(could be more depending on the brand)
then at the iphone screen a pop out will come asking for the passcode or passkey.
The passkey default would be always 0000 or 00000, you should see your product manual or documentation of your specific bluetooth headset if you are not sure on the passcode.
If connection is a success. the headset would blink and the iphone woould veify and lists it to itself.
Now you have a working bluetooth headset.
How do I put it in discover mode?
How to Pair Cardo S-800
1.Turn on
your phone and turn ON its Bluetooth function.
2.Make sure
the headset is turned OFF, then press and hold the
Power
Button for approximately 8 seconds until the LED status
indicator
begins alternating blue and red, indicating that the
headset is
in Pairing Mode.
3.Set the
phone to search for Bluetooth devices by following the
instructions
in the phone’s user guide. This is usually found in the
phone’s
Bluetooth menu and may be referred to as “discover” or
“add” a
device. (Settings > Connectivity > Bluetooth - turn ON - > Discover Devices)
4.After a
few seconds, the phone will list the “Cardo S-800”
as a
discovered
device. Select it from the list and press “oK”
or “yes”.
5.When
prompted, enter the passkey “0000” (4 zeros) and press
“oK” to complete the pairing
6. When
the
pairing pairing is successful the headset’s LED status indicator
will
begin
flashing.
You should
now be able to make and receive calls using your
headset.
To initially connect the headset to your phone, you may
need to
tap the CTRL Button once on the headset.
iMPortAnt:
if pairing is not completed within 2 minutes
while the
Pairing Mode is activated, the headset will return to
Standby
mode, flashing blue once every three seconds and
you must
start the Pairing process again from Step 2 above.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
