20 Most Recent
Cardo BTA II - Cellular phone Bluetooth adapter Wireless Headset Questions & Answers
Pairing a bluetooth adapter without key
hay the key is nothing more then a metal stylus try using a sewing pin in place of the stylus. it is metal and small enough to fit in the hole this will alow you to press the button and set it into pairing mode. good luck and have a nice day!
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
