20 Most Recent
Hunter CareFree Plus 33222 Humidifier Questions & Answers
I have a Hunter Carefree Humidifier Plus. When I
We were having the same problem. Here is how I fixed it but its hard to explain...
I took the main white part off and laid it side ways on a table looking inside there is a tube that goes from the top towards the main fan then connects to a plastic part that is shaped like a "p" In the middle part of the "p" you an see I tiny little gear. I manually turned the gear with a paper clip a few times and it worked. I had no idea what I was doing but I was determined!!!
Hunter Humidifier #33222
From The Hunter Manual
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes.
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOUR HUMIDIFIER to continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
I bought a hunter humidfier
Hunter carefree humidifiers use a reusable and washable wick this method of humidifying does not produce a fine mist like many centrifugal (cool misting)humidifiers.
The fact that it is producing cold air seems to indicate it is working.
However it would not hurt to check the water intake for blockages it also a good idea to run these models on high for several mins when starting this ensures that water is being pumped up.
Water accumulation in tray under humidifier
what kind of humidifier? Are you getting condensation? Look at the windows in the room with the humidifier, if they are wet with condensation, then you have too much water in the air, also if it's cold enough the water can sometimes just fall instead of being absorbed 100% into the air...
