20 Most Recent HP ProLiant DL580 G5 (438087-001) Server Questions & Answers
Recently I had replaced one of HDD of my DL580 service Raid 5 configuration. After that everything working fine including user connectivity and database access. My question is both the LEDs on replace
After you replaced the drive, did you rebuild the RAID array? Some of the higher end RAID controllers will try to rebuild automatically (if set to do so) but most must be rebuilt manually.
12/25/2014 5:26:48 PM • HP ProLiant... • Answered on Dec 25, 2014
3 long beeps
Sounds like a memory fault, try changing the RAM. of if there are multiple sticks remove them and try booting with one at a time.
1/23/2014 10:39:16 AM • HP ProLiant... • Answered on Jan 23, 2014
HP DL580 g5 hangs on windows loading state after
install latest Hp Proliant service pack & update windows
10/20/2013 7:06:17 AM • HP ProLiant... • Answered on Oct 20, 2013
The server making restart every
Do a power audit on the power goes into the server. Use Microsoft Malicious software removal tooi to check for Malicious software.
12/1/2011 8:10:18 PM • HP ProLiant... • Answered on Dec 01, 2011
DL580 G5 hang
Run RAM disgnostics utility on the server, if you have good RAM swap the RAMs till you get the one causing the problem.
12/1/2011 7:59:27 PM • HP ProLiant... • Answered on Dec 01, 2011
0answers
Raid 10
The porn site have installed it add-on your browser. Check and see if you can see any strange program on add and remove software program window. If you can remove it but you must be sure before doing that. Alternatively, download a malware removaMicrosoft
5/29/2010 6:42:12 AM • HP ProLiant... • Answered on May 29, 2010
What is error code 53?
Event ID 53 happens in a couple of scenerios. It happens for certificate issues, like when 'Certificate authority couldnt be found'.
The solution depends on which scenerio it happens. Refer the below MS article for that
http://support.microsoft.com/kb/932457
3/20/2010 2:17:01 AM • HP ProLiant... • Answered on Mar 20, 2010
How do I fix window 10 to listen audio mp3 cd
NO PC told at all and posted to Proliant server forum that is no PC and as such the OS is not allowed there w10 nor does it have sound chips, at all, its a server running in huge dark, no humans server farm..... so let me guess you posted to wrong forum and never told PC model sure. so windows sounds work in the test in control panel yes ! the, MP3 is complex, it can be from high data rate, source and will not play unless converted . one thing to try is use this free app called Audacity https://www.audacityteam.org/ then play it or convert it or buy a USB sound dac that can decode any sound file on earth or learn to test you PC first windows sounds work then in google type simple MP3 sound test https://file-examples.com/index.php/sample-audio-files/sample-mp3-download/ works good above so your MP3 is no good or wrong bit rate. if fails yours only , buy new DAC USB dongle now it plays them all if windows sounds are dead the sound driver is missing or on a server there is no sound chips oops. buy the DAC dongle. if only 1 MP3 fails out of 100's find a better one or buy a DAC.
4/14/2022 2:22:04 PM • HP ProLiant... • Answered on Apr 14, 2022
I want to install win2003 r2 on HP proliant ml350 g3. But didn't found usb port. Please someone advice me! thx.
Have you connected a CD drive to the machine via one of the SATA ports?
9/15/2015 3:54:40 AM • HP ProLiant... • Answered on Sep 15, 2015
Not display error light and not display on monitor
When you turn it on, does the fan come on? How about the hard drive? There is a serries of tests called POST. I amc4rying to find out what starts up and see where the problem is.
7/8/2015 6:01:30 AM • HP ProLiant... • Answered on Jul 08, 2015
Reset bios putty
You need to be specific about the exact model of server that you're using. Features of the various generations of the HP iLO are accessed in different ways. BE SPECIFIC.
6/13/2015 10:00:54 PM • HP ProLiant... • Answered on Jun 13, 2015
Blinking red light and beep sound coming from the front blade Slot 1.
That drive has failed, is it set up with a RAID configuration? Do you have the Dell monitoring software installed? Is it set up with Hot Plug drives? If so replacing the drive with a new one will start the RAID rebuild. Otherwise one way to turn off the bleep is to reboot and go into the RAID controller configuration
6/12/2014 12:00:16 AM • HP ProLiant... • Answered on Jun 12, 2014
Front blade Slot 1
It Indicating something Faulty, if you have something plugged in, remove, and reconnect, If unable to find, check device manager or event log for details, that should have some info.
12/10/2013 9:27:28 AM • HP ProLiant... • Answered on Dec 10, 2013
HP ProLiant DL580 G5 (438087-001) Server Logo
Popular Tags
13 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ProLiant HP
  • ProLiant HP
Most Popular Question
recently replaced one hdd dl580 service
  • Computers & Internet
