20 Most Recent
1998 Isuzu Rodeo Questions & Answers
The vents won't change defrost or floor.
Anonymous, I have this problem too where I can't change my vent location back to face. I've taken out the vent selection panel, and the vent switch know and controls seem to work (not broken). I have a 1989 2.3 liter 2 wheel drive isuzu pickup. Supply vacuum or actuator problem it sounds. Guessing I need to take to mechanic?
My 1998 isuzu rodeo has been running very poorly,
NO!. tensioner has bearing to make it roll. just remove the belt to make have full access to the tensioner. then remove the bolt on center of tensioner. once it was removed you has a free hand to change bearing.
Anti theft dash light is blinking on my 1998 rodeo
I'm assuming its an original alarm or system that came from factory or dealer. When the light blinks is because the alarm is activated. Look underneath the radio the alarm brain might be there. There will be a label on it saying alarm or security system etc. Disconnect the harness to it and try operating your vehicle.
Mi isuzu rodeo se apaga
tengo una izuzu rodeo 1999 motor 2.2 el problema que presenta son;me marca error dela egr y ya se la cambie, en el tablero me marca 2000rpm pero el scaner dice que tiene 780rpm, las revoluciones se normalizan cuando el clima baja como a 22grados celcius, se me quedaron encendido el ventilador de enfriamiento tuve que ponerles relay con la ignicion, no gasta refrigerante de motor pero le cambie los bulbos de temperatura y la falla persiste,el indicador de combustible se sube y se baja y es nuevo con todo y la bomba, alguien me puede ayudar nadie le encuentra el problema
How do I disable the alarm on my '98 Isuzu Rodeo Ls?
The best solution you'll get from books at
www.reliable-store.com
These are books containing inf o on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
Smoking From Oil Fill Hole
smoke when opening the filler is usually normal -smoke from exhaust is problem --and as to oil leak possible valve gasket --if oil level is normal dont add oil {over filling is bad for engine ]
