20 Most Recent 2003 GMC Envoy Questions & Answers
2003 GMC Envoy. Can anyone give me the wiring diagram for my 2003 Envoy transmission please?
Question edited for clarity. Question moved to model category. Click on the images tab. You can also search for a service manual. https://www.google.com/search?q=2003+envoy+transmission+wiring+diagram ..
4/16/2023 12:59:08 PM • 2003 GMC Envoy • Answered on Apr 16, 2023
2answers
2003 GMC Envoy. How to change the alignment of Transfer Case Motor to the shaft index location coming out of the Transfer case?
Transfer case encoder motor alignment
Trail-voy https://www.trailvoy.com > ... > 4x4 Drivetrain Dec 17, 2018 - Hi folks, I have been troubleshooting my 4x4 not engaging and in the process of replacing the transfer case encoder motor on my 08 ... encoder motor alignment Feb 15, 2021 Transfer case motor spline Jan 11, 2021 Question about encoder motor install Jan 7, 2013 No power to wheels. T-case issue? Dec 4, 2021 More results from www.trailvoy.com
How do you align the keyed splines on the transfer case ...
JustAnswer https://www.justanswer.com > GM Repair Dec 26, 2012 - The transfer case when shifted into neutral will allow it to line up with the neutral on the motor. 1 answer · Top answer: I would put everything into neutral. You are correct, the motor is shipped to you in ...
4/13/2023 1:21:23 AM • 2003 GMC Envoy • Answered on Apr 13, 2023
2003 GMC Envoy. I have a different radio in it. My front door speakers work but my back rear door speakers don't work. What could that mean?
That is always a problem with Mix and Match. Check wiring
2003 GMC Envoy Radio Wire Guide
MODIFIEDLIFE https://www.modifiedlife.com > 2003-gmc-envoy-radi... Our 2003 GMC Envoy radio wiring diagram shows you all the radio wire colors and what they do. Table of Contents. 2003 GMC Envoy Radio Wiring Diagram; 2003 GMC ... ..
3/23/2023 8:29:00 PM • 2003 GMC Envoy • Answered on Mar 23, 2023
2003 GMC Envoy heater blower stays on when key is off?
Question edited for clarity. Question moved from Misc to model category. It appears to be a known issue. If the videos don't fix it, you need an auto electrician. https://www.google.com/search?q=mobile+auto+electrician+near+me
3/18/2023 4:35:07 PM • 2003 GMC Envoy • Answered on Mar 18, 2023
2answers
2003 GMC Envoy. The radio and cluster lights wont shut off when the vehicle is off?
That tends to point to an issue with the BCM and its data network. You need an auto electrician with a pro grade scan tool computer to diagnose the issue as it is a strange one.
12/2/2022 4:18:21 AM • 2003 GMC Envoy • Answered on Dec 02, 2022
2answers
What is the cylinder order in a 2003 gmc envoy
1-5-3-6-2-4 I'm going to completely assume that the GMC envoy, based on what I can gather, uses the old 235 Chevy (50's) design, since it reduced balance issues, and therefore, this would be the right sequence.
11/27/2022 1:01:06 AM • 2003 GMC Envoy • Answered on Nov 27, 2022
2003 GMC Envoy. How do I hotwire my car as my key ignition messed up.
You can't, that only happens in old movies. Your immobilizer works with a chip in the key transmitting a code to the transponder in the ignition column which sends the code to the engine computer, the body control computer, the transmission computer and the ignition module. They all have a chat about it and then decide if they will let the car have power to the ignition and fuel pump. This all happens fast between the ignition lighting up and turning the starter motor. There are always people with other ideas though and make money from YouTube videos. https://www.google.com/search?q=2003+gmc+envoy+bypass+immobilizer+bypass It is better to fix the problem, not find a way around it. The cheapest solution is a mobile auto locksmith. Hotwiring and stealing cars has virtually stopped since the advent of immobilizers.
11/22/2022 9:04:29 PM • 2003 GMC Envoy • Answered on Nov 22, 2022
How many quarts of oil is used in a 2003 GMC Envoy
Hello kirajmi; My name is Roger and I will help you. The correct amount of oil for your engine when changing the oil and oil filter is. With a 4.2 V-6 engine 7qts. If you have a 5.3 V-8 engine use 6.0qts. of oil. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
10/8/2022 7:28:00 PM • 2003 GMC Envoy • Answered on Oct 08, 2022
SLT 4.2l 2wd. Where do the two vacuum lines go from the top of transmission?
no such thing , vents yes, ATF line yes , vacuum no. wires yes. only super old transmissions use vacuum modulators let me guess you see to hoses an assume vacuum? the metal in pair is tranny cooles the service manual covers this. 2003 GMC Envoy 4,2 2wd' gas 4L60E TRANSMisson shifts by TCM computer, totally. no vacuum modulator there ever. learn to follow line the other direction to the cooler (2 kinds)
9/9/2022 9:03:26 PM • 2003 GMC Envoy • Answered on Sep 09, 2022
2003 envoy low beams will not work.fuses
For the I6 engine there is a relay for low beams, it's relay # 46. Switch it with relay #45 (runs the fan, same model relay) and see if your lights now come on. These 2 relays are the only 2 black ones in there (part # 15016745). Also, try to clean the contacts very well on the fuse box and the relay. If not, you may have some frayed wiring in the harness.
By the way, the high beam relay is #43, the gray one next to the windshield wiper relay #42.frontfuses.jpg
8/16/2022 10:54:28 AM • 2003 GMC Envoy • Answered on Aug 16, 2022
2answers
03 GMC envoy..wont start all
Try giving the starter a whack with a hammer or end of broomstick if it tries or goes, replace the starter
7/21/2022 10:27:01 PM • 2003 GMC Envoy • Answered on Jul 21, 2022
2answers
How to reset 03 gmc envoy computer
dis-connect both battery cables from the battery. Touch them together and re-connect them to the battery. remember disconnect both, don't be lazy and only disconnect one.
2/4/2022 4:39:51 PM • 2003 GMC Envoy • Answered on Feb 04, 2022
XL. Why is 'reduce eng.' light on?
Reduced engine power is a problem with the electronic throttle control . You need to have a scan tool hooked up to read codes stored . REDUCED ENGINE POWER: Refer to Powertrain Control Module Description in Engine Controls - 4.8L, 5.3L, and 6.0L Reduced Engine Power Mode When the PCM detects a problem with the throttle actuator control (TAC) system the PCM enters one of the following Reduced Engine Power Modes: • Acceleration Limiting--The control module will continue to use the accelerator pedal for throttle control, however the vehicle acceleration is limited. • Limited Throttle Mode--The control module will continue to use the accelerator pedal for throttle control, however the maximum throttle opening is limited. • Throttle Default Mode--The control module will turn off the throttle actuator. • Forced Idle Mode--The control module will perform the following actions: - Limit engine speed to idle by positioning throttle position, or by controlling fuel and spark if throttle is turned off. - Ignore accelerator pedal input. • Engine Shutdown Mode--The control module will disable fuel and de-energize the throttle actuator.
9/9/2021 10:53:53 PM • 2003 GMC Envoy • Answered on Sep 09, 2021
Reset button on 2003envoy ti put in gear
Hi Teresa, I recently had the same problem as my wife's envoy wouldn't start and shift out of park so I could tow it home. You have to remove the shift nob and center console to access the silver button on the bottom right side of the shifting mechanism, but before your center console will lift out of position there are several screws under cup holder rubber mats and the rubber mats inside the center console.
8/19/2021 8:34:56 PM • 2003 GMC Envoy • Answered on Aug 19, 2021
3answers
2003 gmc envoy emergency brake light is on and there's a ding ding ding ding nouse. checked brake fluid. How do I stop the Noise or fix it
the noise is telling you the emergency brake is on (or it thinks it is) emergency brakes don't use any fluids as they are totally mechanical on your truck , id first try setting the brake and then releasing it again , if this still doesn't clear the light on then id have your mechanic look at it , might require an adjustment id be cautious in driving it if theres any possibility that brake is dragging as this will severely overheat your brakes requiring you to replace them early
8/1/2021 5:07:37 PM • 2003 GMC Envoy • Answered on Aug 01, 2021
2answers
GMC Envoy 2003 SLT only the parking lights and fog lights work. The low beam and high beam don't work. Please help
Well, the problem is that I dont know the reason, you should investigate. There could be issues with lamps (must get new) or electricity problems (must head to auto-service)
4/16/2021 9:23:23 PM • 2003 GMC Envoy • Answered on Apr 16, 2021
Where is the EGR valve?
The 4.2 I6 doesn't have one.
2/17/2021 10:08:51 PM • 2003 GMC Envoy • Answered on Feb 17, 2021
2answers
03 GMC Envoy Air Suspension fuse location?
The main fuse block is under the hood in plain view. It has a black plastic cover and will have the word fuse on it. Pull the cover off (some have a single bolt, some you push in tabs). It is the #15 fuse. I tried to upload a pic but there is an issue with the site. There are a lot of pictures online. Hope that helps
12/23/2020 12:37:11 PM • 2003 GMC Envoy • Answered on Dec 23, 2020
2,017 questions posted
Popular Products
2004 GMC Envoy
2004 GMC Envoy
2,225 Questions
2002 GMC Envoy
2002 GMC Envoy
1,418 Questions
2006 GMC Envoy
2006 GMC Envoy
593 Questions
2005 GMC Envoy
2005 GMC Envoy
540 Questions
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
View Most Popular
Envoy GMC
  • Envoy GMC
Most Popular Question
different radio in 2003 gmc envoy front
  • Cars & Trucks
